Re: Stones getting trapped in the disk brakes of Skoda Fabia Quote:
Originally Posted by greenhorn Thanks to this thread I sorted out this issue in a friend's wagon r. Had called maruti on road service which diagnosed it as a wheel bearing issue and said the vehicle is drivable, but fix it asap. Stumbled onto this thread, thought I'd give it a shot, and problem solved. Two laps in reverse around my flat, and the noise is gone |
Faced this issue in my WagonR couple of months back. In my case, the reversing a few meters on the road did stop the noise but the stone was still there. It was removed after opening and un-mounting the wheel. This small stone chip (~4-5 mm, used while road tarring) was lodged between the disk and the protective plate behind it. |
