Guys,
My Accent CRDi AC is not good and is particularly can experience it during these hot summer days.
The cabin is not getting cooled even after 10 mins with blower at max speed. At nights or not-so-sunny day, I found it ok (not great, but still it cools the cabin within sometime).
Its a 2003 model car, and I got it last September.
This is the first summer with this car and am really getting fried inside when I take the car out during day time.
H.A.S.S & my car mechanic - both said AC is fine.
Is really all Accent's AC ineffective? or Am I missing something here?
Anyways, decided to take it to an independent AC mechanic in Trichy to check the gas levels and will check for AC cleaning.
Please lemme know if anything else need to be checked. Also, suggest some good AC mechanics in Trichy.
Get the cooling coil cleaned,it is located just behind the dashboard,and can be cleaned without Removing the dashboard.
I was facing a similar issue with my Accent and there was a drastic change after this.
The Grill temperature should be around 3-7 degrees for a properly working AC,you can check it using a digital thermometer.
Have the a/c refrigerant checked; the gas might need to be replenished.
Also, have the a/c lines checked for any leaks. Is the thermostat working fine?
Thanks Akshay4587 & libranof1987.
Will get the cooling coil, grill temperature, refrigerant & cooling lines checked.
@libranof1987, I think thermostat is working fine. The temp level is getting varied, if I switch the knob to various positions.
Check the AC gas also for any leaks in the lines
If in Bangalore take it to Sejal motors (details in Bangalore directory) one of my friend also a TBHP member had taken his Honda City with the same issue and the gas was the culprit. They fixed it for him
narayanang76
I had once faced such a issue with my Accent Viva CRDi and when got it checked with A.S.S they identified that the gas had leaked and it had to be refilled.
When this problem occurs in summers, the culprit in most often cases is the gas getting over.
What sun film do you have on the windshield? And are you parking in direct line of sunlight?
Apart from the gas getting over, an exposed glass area could heat up quicker
Accent CRDi has one of the better A/C compressors. My recent trip to Kalahasti proved to be a good test and it came out in flying colors
From you explanation it seems that the cooling isn't good when the cabin is hot or the outside temperature is high
Please check the evaporator coil - There is a small glass window - If you see bubbles the refrigerant needs to be replenished.
And clean the A/C filter and the cooling coil checked
@all, firstly Thanks everyone for your inputs.
Originally Posted by mobike008
(Post 2374430)
When this problem occurs in summers, the culprit in most often cases is the gas getting over. |
Originally Posted by narayanang76
(Post 2374429)
narayanang76 |
I'm in Trichy currently and will try out an AC mechanic suggested by my friend. Will ask the AC mechanic to check for leaks & gas levels.
If no improvements, anyways I'm driving back to B'lore this weekend and will get it checked in Sejal Motors.
Originally Posted by selfdrive
(Post 2374497)
Apart from the gas getting over, an exposed glass area could heat up quicker |
The sun film holds good still. Normally, I park the car in shades. This cooling issue is there even when cabin is warm not very hot. In nights, its OK.
Originally Posted by csateesh
(Post 2374546)
Cheers |
Good to know that its not a common issue. its a relief. Will get the Evaporator coil & A/c filter checked.
Will ask the mechanic to have a check on these pointers. I hope, the issue will get sorted quickly. :)
Karthik
Any update on the issue..
Just curious if you have been able to crack the problem
(Post 2376773)
Karthik
Yet to visit a mechanic. had a very busy week :(
Yesterday I drove back to Bangalore. So, will visit Sejal motors this weekend as suggested by narayanang76.
