Re: Engine stalls after running for long with AC on A few other questions;
Does the AC cool properly along the whole power band. (e.g. at any speed, engine RPM)
Does the engine idle properly at a steady RPMS or does it hunt a bit? (RPM going up and down a bit). If so, aux valve is likely suspect.
Is the current idle RPM normal? If that is a little low to start with, that could be a problem too.
If you can, do a full OBD scan, preferably with a manufacturer/model specific scanner.
I would suspect IAC or auxiliary air valve (not sure what term is used for the Santro.
That is the most straightforward explanation! Your AC puts an extra load on the engine. These devices are supposed to add a bit of air (and fuel) so your engine sticks to the same idle RPM under a slightly heavier load.
It is usually a problem with either the valve sticking or some air leaks across a seal. Especially the latter can be temperature related, so with a warm engine it could be worse than when your engine is still cold. It is/used to be a well known problem on all Ford Fiesta versions.
To get some idea if these valves are working not it can be checked very easily. let the engine idle, switch on the AC. Do you notice a dip in RPM that is not recovered within half a second? Something is wrong then.
If the IAC/Aux valve work properly, I would have the throttle body checked. Sometimes, due to wear and or dirt accumulating you might get similar problems
I am not sure how the AC is driven on your car. But if it is a belt driven AC, do check the condition of the belt and the tension. It can cause all sorts of erratic engine behaviour. Again, depending on the exact AC set up, a bearing that is on its way out can cause the same behaviour. But usually that will get worse over time, fairly quickly.
Good luck, let us know what you find eventually.
Jeroen |
