Search this Thread | 55,846 views |
1st October 2013, 07:08 | #46 | |
Distinguished - BHPian | Re: Engine size inversely proportional to Fuel efficiency? Quote:
So for a given size and weight of an engine, adding a turbo increases the horsepower. It does not necessarily make it a more efficient engine perse. Jeroen | |
() Thanks |
1st October 2013, 09:27 | #47 | |
BHPian Join Date: Jul 2013 Location: Chennai
Thanked: 347 Times
Now for people who think that since turbo offers these benefits, why aren't all cars fitted with turbo chargers. The answer is, Turbo charger and its accessories cost a bomb. Hence manufacturers avoid it. | |
() Thanks |
1st October 2013, 11:37 | #48 | |
BHPian Join Date: Aug 2013 Location: Bangalore
Thanked: 56 Times
This kind of data is really useful at arriving at a general consensus on whether or not engine size matters or perhaps what really matters among the cars in the market. I would like to add couple more piece of data: 6. Santro Petrol AT 1.1L - 8-9km in city 7. Fortuner Diesel AT 3L - 10km in city 8. i20 Petrol AT 1.4L - 8km in city 9. Innova Diesel 2.5L - 11 in city All with 100% A/c On. bsdbsd, Is that Verna AT Petrol version? It better be otherwise it's beyond me how it could give lesser mileage than my Fortuner AT? | |
(1) Thanks |
The following BHPian Thanks kaizanfan for this useful post: | bsdbsd |
1st October 2013, 11:54 | #49 | |
BHPian Join Date: Jan 2010 Location: Bangalore
Thanked: 472 Times
All the cars mentioned in my list are Petrol cars. There is one more Diesel Verna AT in my office (1.5 or 1.6...not sure), which goes 10-11 kms for a litre of Diesel. So its very reasonable to assume that 8-11 is the average range for all types of moving contraptions, across fuel types and engine sizes (AT), under standard Indian city driving conditions. Add 10-15% for non AT vehicles. If you get something better, then its good for you. I am interested in experts take on this real life data. Last edited by bsdbsd : 1st October 2013 at 12:00. Reason: Incorrect engine size correction | |
() Thanks |
1st October 2013, 13:28 | #50 |
Senior - BHPian | Re: Engine size inversely proportional to Fuel efficiency? Efficient engine also plays a part in FE. My K10's 1L engine gives 9-10 in very short distances (0.5 to 1km between stops), but in normal Delhi B2B traffic it increases to 12, where as the City with its 1.5L engine gives better average. |
() Thanks |
1st October 2013, 14:29 | #51 | |
Any increase in mileage and reduced emission come from a host of different bit and pieces that need to be added and several design adjustedment on the cilinder head, injection system etc in conjunction to installing the turbo. Jeroen | |
() Thanks |
1st October 2013, 16:52 | #52 | |
Thanked: 347 Times
All turbo does is increase the volumetric efficiency of the engine which translates that it aids better combustion resulting in lower emission. You are right with "The more power is as per my earlier post, that's what a turbo does" it is the primary objective of turbo, it also provides secondary benefits i.e, decreased emission and increased mileage (Again Turbo charged vehicles are fun to drive and turns people into jeremy clarkson wanting more POWEEEEEEEEEEEER. People tend to have fun leading to drop in mileage). Again I would like to insist that under "SAME CONDITIONS" turbocharged engine returns better mileage. | |
() Thanks |
1st October 2013, 20:26 | #53 | |
Naturally, we don't pipe in pure oxygen but atmospheric air, so we also get various oxides of nitrogen, and carbon monoxide due to incomplete combustion. | |
() Thanks |
1st October 2013, 21:55 | #54 | |
Sorry, you are mistaken. Volumetric efficiency is not a measure of fuel efficiency perse. There are several definitions around, but give or take it is along the following lines: It is defined as the volume flow rate of air into the intake system divided by the rate at which volume is displaced by the piston. Nothing to do with fuel efficiency. Sometimes you'll see a definition about how effectively an engine system can pull an intake charge through the cylinder. There are two different things we are sort of discussing. One, and we seem to be in agreement on this one, a turbo increases power for a given engine weight and size. And two, whether a turbo increases the fuel efficiency. You claim it gives better combustion and resulting in lower emission. But you don't say how it does that. You'd be hard pressed to go into the details, because essentially it doesn't. Why does it give better combustion? I wouldn't know, please explain. Several members already pointed out that in order to increase power you need more fuel. Engines are designed to run at a very specific air to fuel ratio. Basically so many air molecules to fuel molecules. The engines runs most efficient at a given ratio and every modern car is chock a block full of electronics, sensors, flow meters and what have you that regulate the air to fuel ratio in a very narrow band. Next to that, there are all sort of other design features that enable to burn fuel as efficiently as possible and are really an integral part of the overall design of a (turbo) engine. Such as compression ratio, size and shape of the inlet/outlet channel, size and shape of the cilinder head, exhaust system etc. They are specific to a turbo being part of an engine design as I tried to point out earlier. When you add a turbo to an engine, you put more air molecules into the cylinder. Therefor you can add more fuel, but the ratio stays the same. So there is no efficiency gain whatsoever. Your ECU sees to that! There are quite a few other factors that we do need to take into consideration. As the turbo actually compresses the inlet air, it also increase the inlet temperature, and as most of us know that is detrimental to engine performance! Rest assured, the power increase offsets that effect, unless we are talking about really high turbo boost pressures in which case you will see intercoolers coming into play. Now, due to the higher differential pressure across the engine (higher inlet pressure due to turbo boost) there is probably some positive scavenging effect. That might again, produce some more HP or maybe make the combustion process more efficiently. Essentially better scavenging ensures more residual exhaust gasses get spewed out of the cylinder. To get the maximum effect out of this the cilinder head, inlet, outlet channels and exhaust system need to be designed to allow this. (see my earlier post where I mention this). Also, turbo charged engines tend to operate on higher average cilinder pressure and higher maximum combustion pressure. Again, that explains the higher HP output and might allow for a more efficient combustion. But again, to my earlier point, you need to add a whole bunch of stuff and design it specifically so, see above. The problem in this discussion is that we are trying to discuss something theoretical, whereas most of our experiences are in the real world. But bolting a turbo onto an engine and think it will run more efficiently is simply not going to happen. You'd be lucky to get an increase in power. What is true, as agreed, is that turbo's give a higher HP output. In addition, modern turbo charged cars, tend to have a much better torque curve, allowing for easier acceleration, less shifts etc. So what you actually see is that car manufacturers are using smaller engines, with turbo's. That gives a weight advantage. Also, smaller engines tend to more thermodynamically efficient, and because of the turbo you get a better power/torque curve. All of that results in a more fuel efficient car/engine combination. So to go back to the original question of this thread whether bigger engines are less efficient than smaller ones. If the smaller one is designed with a turbo and produces the same HP as the bigger one, the smaller one is likely to be more fuel efficient! Jeroen Last edited by Jeroen : 1st October 2013 at 22:03. | |
(1) Thanks |
The following BHPian Thanks Jeroen for this useful post: | kaizanfan |
1st October 2013, 23:22 | #55 |
BHPian | Re: Engine size inversely proportional to Fuel efficiency? Hi I feel we have mixed up the discussion a bit here. Coming back to the moot question "Engine size inversely proportional to fuel efficiency". Frankly there is no term as fuel efficiency. Theoretically power produced in the engine is directly proportional to only two things ie mass in the cylinder and calorific value of the fuel used. Mass in cylinder is mixture of air and fuel. Behaviour of gases in the cylinder is governed by Ideal gas equation stating that PV=nRT, where P = pressure, V= volume, n=mass of gas, T= Temp and R is gas constant. Linking up the above two aspects we can say that power of an engine is directly proportional to pressure in the cylinder head when it is in fully compressed position, Volume of the cylinder(ie size) and inversely to temperature of the gas. (density of gas gets covered in this equation) As an engine designer your job is to get best/desired power output with least amount of fuel consumption. (One of the QRs) So you tinker with pressure, volume and operating temperatures and try to work out the best combination to achieve the objective. Use of turbo chargers, cam setting, fitment of swirlers, multiport injections, type of fuel to be used various octane nos or cetane nos etc the list is pretty long, all come under adjustment for the three critical factors. These days electronics have made the job easier as inputs and outputs can be sensed and controlled more accurately. Fuel consumption of an engine is measured not by the number kms done by it but by the amount of fuel used to generate one unit of power. It can be seen that for checking fuel consumed/km above factors are constant and we have discussed quite elaborately in the thread that fuel consumption/ km is a different ball game and dependent on various other factors beside the above stated. Cheers |
() Thanks |
2nd October 2013, 08:28 | #56 | |
Fuel efficiency or mileage expressed in km/l is a different factor, although the above weighs in pretty hefty obviously. But lots of other factors, ranging from aerodynamics, tires make and size, gearbox, etc. There are a few cars on the market with are available in a certain engine size (e.g. 2.0 liter) with and without turbo's. You will find that for some the turbo version is slightly more fuel efficient (i.e. better mileage, km/l). That is no so much due to the turbo version being able to extract more power out of a unit of fuel as it is to the other factors I mentioned. Different torque curve and they will (just about all) come with a different gearbox than the non turbo version. Again, only to make optimal use of the specific power/torque delivery of the turbo based engine. Jeroen | |
() Thanks |
2nd October 2013, 12:20 | #57 | |
Thanked: 347 Times
“Engines rely on the downward stroke of a piston to create a low-pressure area (less than atmospheric pressure) above the piston in order to draw air through the intake system. Most naturally aspirated engines cannot inhale their full displacement of atmospheric density air. The measure of this loss or inefficiency in four stroke engines is called volumetric efficiency. If the density of the intake air above the piston is equal to atmospheric, then the engine would have 100% volumetric efficiency. Unfortunately, most engines fail to achieve this level of performance” This means that in order to create a single unit of power, more fuel is sent with lower quantity of air (This is done with help of electronics). This is called a rich mixture. WRT increased fuel efficiency, what I meant is that under ideal conditions just the right quantity of air and fuel are mixed to create a single unit of power. Your consideration is that with more air being sent, more fuel is required to create more power. Working of turbo: Turbo works with the help of exhaust gases, when you depress the accelerator, the engine produces more (hot) exhaust gases and this gas runs the turbo. With the help of turbo, a depressed accelerator increases the pressure of intake gas. At lower RPM, there is not enough exhaust gases and this is not effective to run the turbo, this is called Turbo lag. Ways to increase the level of atomization (A fine microscopically dispersed fuel in air) One way is to create a fine mist of fuel using injectors. The other is by increasing the density of intake air (done with the help of turbo and intercooler). For people who want to know more on how these systems works, feel free to google some videos. Here are the answers your questions. Firstly, I am never of the opinion that volumetric efficiency is a measure of fuel efficiency. I again like to emphasise that higher the Volumetric efficiency more complete the combustion is. I agree with the accessories parts and electronics part, I wanted to simplify things and not make it complicated. Theoretically, turbo aids (end result) in better combustion leading to better usage of fuel to produce a single unit of power. Theory assumes that all the conditions are ideal and in that case, yes, smaller engines consume less fuel to produce a unit of power. I have attached a couple of links to back up my views with respect to turbos. Jeroen, I rest my case. Sources: http://www02.abb.com/global/CNABB/CN...1!OpenDocument http://innovatize.blogspot.in/2012/0...ine-power.html http://www.ijceronline.com/papers/Vo...3301770180.pdf | |
(1) Thanks |
The following BHPian Thanks katchkamalesh for this useful post: | kaizanfan |
2nd October 2013, 14:07 | #58 |
Thanked: 56 Times
| Re: Engine size inversely proportional to Fuel efficiency? Found useful information on the following pages: http://auto.howstuffworks.com/question685.htm http://auto.howstuffworks.com/question395.htm http://auto.howstuffworks.com/10-way...ine.htm#page=0 |
() Thanks |
2nd October 2013, 20:58 | #59 | ||||||||||
Rich/lean can be momentarily during acceleration/deceleration but your engine management system will always adjust to the optimal Lambda setting. It will never ever get the emission right otherwise. An engine becomes sustainable more fuel efficient (more HP per unit of fuel) when you increase the combustion efficiency. An engine can be designed to run lean, but that is irrespective of turbo or NA. On planes, like the one I fly, you control the mixture separately and at higher altitudes, i.e. lower densities, you "lean" the mixtures, which gives you a better fuel efficiency. Technically, its not leaning. Its just adjusting for a different number of air molecules. The ratio stays the same See also: http://en.wikipedia.org/wiki/Air–fuel_ratio Quote:
There is a general misconception that turbo engines run with higher combustion pressures and temperatures. (i.e higher density) In essence this is not true. Normally aspirated engines are designed in such a way that they already have the most optimal pressure and temperature for the combustion to take place. Think of a petrol engine. Too high a temperature and the petrol will start to burn to early or unevenly, causing knock. So what you will see is that turbo version of NA engines will have a lower compression ratio. Take for instance my Jaguar XJR. 4.0L V8 supercharged engine. Compression ratio 9.0:1. The very same engine sits in the non supercharged NA XJ8. No supercharger but the compression ratio is 10.75:1. Do the math of an adiabatic process and you will find that both the supercharged and the NA engine operate at near enough identical pressure and temperatures at the end of the compression stroke! So there is no difference in pre-conditions to the combustion process when comparing NA engines to supercharged or turbo charged engine. A turbo or Supercharged engine produces more HP/torgue because its average pressure during the power stroke is higher. If you want more detail, we need to go into the details of making everybody understand a P-V diagram showing how the indicated Horsepower is generated. Same is true, for some different reason for diesels. Based on the above, I guess you can figure that out. Contrary to your statement the intercooler doesn't increase the density of the air intake. It lowers the temperature of the intake! So density decreases. Intercoolers are used in combination with high Turbo boost pressures. These high turbo pressures increase the air intake substantially. If this relatively high temperature is subsequently compressed by the piston, the temperature at the end of the compression stroke would be way too high. Hence intercoolers are introduced, to reduce the temperature of the intake air after it comes out of the turbo and before it goes into the cylinder. Quote:
As I said earlier, there might well be some positive scavenging effects, but I don't know how to quantify those. Quote:
Don't; you say you simplify and don't want to use to much technical jargon. I'd like to think I can handle that. I've met quite a few Team BHP forum members in person in Delhi and I know several who will be very happy to see you bring in the detail and the technical knowledge. Looking forward to your detailed, factual, technical explanation why turbo engines are more fuel efficient. I.e. use less fuel to produce a unit of power compared to NA engine. Jeroen Last edited by Jeroen : 2nd October 2013 at 21:04. | ||||||||||
() Thanks |
2nd October 2013, 21:40 | #60 |
Thanked: 347 Times
| Re: Engine size inversely proportional to Fuel efficiency? That is all I have to say and I have explained what a turbo charger does. I have all reasons to be believe in what I have posted and I have also backed it up with the links. I urge all of you you to read all my posts in this thread once again. And since this is a public forum, Its is not just for you, me or a few who understand these technical terms. Knowledge sharing should be simple. This is my school of thought. |
() Thanks |
