Old 25th March 2004, 15:02   #1
Thanked: 321,766 Times
you know about the valves that let air into the engine and let exhaust out of the engine. You also know about the camshaft that controls the valves. The camshaft uses rotating lobes that push against the valves to open and close them. This animation from How Camshafts Work can help you understand how the camshaft opens and closes the valves:
It turns out that there is significant relationship between the way the lobes are ground on the camshaft and the way the engine performs in different rpm (rotations per minute) ranges. To understand why this is the case, imagine that we are running an engine extremely slowly -- at just 10 or 20 rpm, so it takes the piston seconds to complete a cycle. It would be impossible to actually run a normal engine this slowly, but imagine that we could. We would want to grind the camshaft so that, just as the piston starts moving downward in the intake stroke, the intake valve would open. The intake valve would close right as the piston bottoms out. Then the exhaust valve would open right as the piston bottoms out at the end of the combustion stroke and would close as the piston completes the exhaust stroke. That would work great for the engine as long as it ran at this very slow speed.
When you increase the rpm, however, this configuration for the camshaft does not work well. If the engine is running at 4,000 rpm, the valves are opening and closing 2,000 times every minute, or thirty to fourty times every second. When the intake valve opens right at the top of the intake stroke, it turns out that the piston has a lot of trouble getting the air moving into the cylinder in the short time available (a fraction of a second). Therefore, at higher rpm ranges you want the intake valve to open prior to the intake stroke -- actually back in the exhaust stroke -- so that by the time the piston starts moving downward in the intake stroke, the valve is open and air moves freely into the cylinder during the entire intake stroke. This is something of a simplification, but you get the idea. For maximum engine performance at low engine speeds, the valves need to open and close differently than they do at higher engine speeds. If you put in a good low-speed camshaft, it hurts the engine's performance at high speeds, and if you put in a good high-speed camshaft it hurts the engine's performance at low speeds (and in extreme cases can make it very hard to start the engine!).
VTEC (which stands for Variable Valve Timing and Lift Electronic Control) is an electronic and mechanical system in some Honda engines that allows the engine to effectively have multiple camshafts. As the engine moves into different rpm ranges, the engine's computer can activate alternate lobes on the camshaft and change the cam's timing. In this way, the engine gets the best features of low-speed and high-speed camshafts in the same engine. Several of the links below go into the actual mechanics of the VTEC system if you are interested.
Several engine manufacturers are experimenting with systems that would allow infinite variability in valve timing. For example, imagine that each valve had a solenoid on it that could open and close the valve under computer control rather than relying on a camshaft. With this type of system, you would get maximum engine performance at every rpm range. Something to look forward to in the future...
Article sourced from how stuff works
GTO is offline   (1) Thanks
Old 26th March 2004, 15:15   #2
adityapd's Avatar
Thanked: 9 Times
Damn good explaination GTO...meanhwile all of ur here are really curious to know about the progress of your VTEC so far ...whassup dude ?
cheers
aditya
adityapd is offline
Old 26th March 2004, 16:43   #3
Shan2nu's Avatar
Thanked: 127 Times
Here's my progress........
Regards...
Shan2nu
Shan2nu is offline
Old 26th March 2004, 16:53   #4
Excellent Article And An Excellent Picture Dude
rgowani is offline
Old 28th March 2004, 16:00   #5
Sam
The VTEC is basically a SOHC engine below 4000 revs and a DOHC after 4000. Its almost like a getting a Turbo boost at 4000 revs but not really a kicking boost. The BMW has a similar variable valve timing system known as the VANOS. the old M3 has it the new E46 has an updated version. The Company which pioneered this type of technology is Alfa, many years ago.
Sam is offline
Old 28th March 2004, 16:44   #6
Dear God, What an amazing picture of Shantanu and his Vtec. I feel bad about missing it earlier...but thats some darned good photography (but then, isnt it the subject that really makes the picture?)
GTO is offline
Old 28th March 2004, 19:52   #7
Shan2nu's Avatar
Thanked: 127 Times
The subjects friend took the pic. The subject is......hehe you know where.
Regards...
Shan2nu
Shan2nu is offline
