Originally Posted by heelntoe in fiats i believe there is an mpfi light that has to go off for you to crank the engine. |
u are right, that light takes around 10 secs to go off and when you are stuck in traffic that light is the last thing on your mind.
in many cases if the engine is killed on the move it is advisable to crank the engine right away as the cars with power brakes can end up in a big mess
Yes, the brakes will be less effective when the engine is in off state. It is better that it is started immediately on the move.
Originally Posted by tif0si in some cars like in my palio,once u turn on the ignition and start the car and if u try to start it again the key does not turn, it has some kind of a lock i guess, coz even i tried to start the car accidently a couple of times even though the engine was running,but i could not do so as the key would not turn then i realised that the engine was running, |
That's cool..:)
Any idea whether the same kind of feature is available for NHC as well? I don't wanna try and test it out :p Just curious to know from fellow BHPians who have had similar experience with their NHC or even OHC in the past.
