Old 14th December 2006, 15:16   #1
katalyst's Avatar
Engine Warm Up
Every morning when I start my Lancer (2000 Petrol GLXi), I have to wait for a good 4-5 minutes before the engine starts responding to the throttle. Is this normal?
If I do not wait, the car jerks like crazy and hardly moves. I have no experienced this with the Wagon R - which is ready to go almost immediatly.
katalyst is offline
Old 14th December 2006, 16:24   #2
sreenivass's Avatar
Thanked: 44 Times
I had this problem with my Yezdi
I had similar problems with my Yezdi, mechanics told me its because of moisture/ water content inside that causes this. Does this give any clue ?
Does the problem happen only in winters or during summer too ?
sreenivass is offline
Old 14th December 2006, 17:09   #3
Shan2nu's Avatar
Thanked: 125 Times
Shouldn't happen with any MPFi car. At max, you might have to wait 30 secs before you start moving.
I remember having this prob on our carb Esteem but not for 5 mins.
Shan2nu
Shan2nu is offline
Old 14th December 2006, 17:24   #4
abhibh's Avatar
Thanked: 39 Times
I face same problem but not for more than 1 - 2 min in CARB M800 i am currently driving. Never ever faced a problem with MPFi car ever. 1 self and car is ready to go even at 1degree temp..
abhibh is offline
Old 14th December 2006, 17:28   #5
faddy's Avatar
same problem i have to wait more than 10 minutz !!!!!
faddy is offline
Old 14th December 2006, 20:08   #6
Thanked: 67 Times
My Esteem dosent like winters
As soon as i start my Esteem 2001 MPFI it takes like 10 minutes to reach normal RPM. It stays between 2000 to 2500 rpm for this time once the engine warms up it comes back to 900rpm. Also in the morning the temp gauge dose not go above 1/4 even if i drive the car for 30KM- Greater Noida Express Highway driving at around 90-100 KMPH . Is that normal for winters.
bhogalrajnish is offline
Old 14th December 2006, 20:48   #7
theMAG's Avatar
Thanked: 1,808 Times
Compression ratio might have dropped. Spark plugs might need replacement.
A petrol car isnt expected to be sluggish to throttle input under normal circumstances.
theMAG is offline
Old 14th December 2006, 21:42   #8
vezj420's Avatar
Thanked: 23 Times
Re: Engine warmup on an EFI car
What I do, when I first get in the car in the morning, is start the engine before doing all my other 'preparing' - i.e. putting sunglasses on, making sure my bag has everything in the right place, waving bye, etc. This should give the engine at least 30 secs of good idle time to warm up.
Then, I gently rev her (still neutral) to almost 2k rpms and let it drop (repeated twice)
Also, when I finally take off, I try to stay in 1st gear until the first 2 - 2.5k rpms before shifting to 2nd.
I know it seems like a dam' ritual (it sorta is!), but doing ALL of the above for me (car in question - Ikon 1.6) really helps with two major issues - engine warmup and the avoidance of fuel 'pooling' in the intake manifold (both of which, I think, are culprits of the much hated 'jerking'). Now the car almost never jerks even at the initial gear shifts of the day.....
However, as theMAG mentioned, no throttle response initially is something seriously wrong, most likely with your ignition......you don't have any ignition timing mods, do you....?
vezj420 is offline
Old 14th December 2006, 21:47   #9
abhibh's Avatar
Thanked: 39 Times
I just pull the choke for 30 secs now days but it still jerks and i sometimes drive with choke for about 50 mtrs.. This is working ok but it still jerks
abhibh is offline
Old 14th December 2006, 22:26   #10
rr_zen's Avatar
Thanked: 400 Times
Well this happens to my esteem mpfi too and my brother's zen (mpfi). I was initially worried about this phenomenon and later came to know that its common for all mpfi vehicles to behave like this on cold start. There is a residue of fuel left behind in the fuel injectors at the end of the day and that is the reason for the car to operate at a higher rpm during cold start the next day until the additional fuel is burnt out.
rr_zen is offline
Old 14th December 2006, 23:12   #11
Shan2nu's Avatar
Thanked: 125 Times
I think you mean compression pressure.
Shan2nu
Shan2nu is offline
Old 15th December 2006, 00:29   #12
abhibh's Avatar
Thanked: 39 Times
Frankly i never had that problem. I agree car goes to a high rpm but only for 10 secs at max. I will try starting a MPFi tom, may be i am wrong but car never took more than 10 secs to go back to normal rpm.
abhibh is offline
Old 15th December 2006, 03:39   #13
rr_zen's Avatar
Thanked: 400 Times
Agreed..It doesnt take 10 minutes but maybe about 30 seconds for my car and to be on the safer side I leave it on few more seconds and I dont engage the gear (forward or reverse) before letting the engine run for atleast a minute or two when performing a cold start so as to avoid wear and tear that happens at that time.
rr_zen is offline
Old 15th December 2006, 04:57   #14
hellspawn's Avatar
Thanked: 7 Times
Infractions: 0/1 (10)
takes my zen mpfi 1min to stabiise when started in the moning.but my hondas and the siena do not face any such problem.even when you start them in the morning they idle at 800-1000 rpm.
i guess its more pronounced with the maruti engines.maybe has something to do with the fact that zen,esteem,baleno have aluminium heads.
hellspawn is offline
Old 15th December 2006, 10:55   #15
sreenivass's Avatar
Thanked: 44 Times
Starts at 1200 RPM
In the case of my Petra Petrol the cold start idle RPM is about 1200+ and settles down to about 600-800 in one or two mins. Cold start Idle RPM 800-1000 is a surprise to me, have not seen in any one of my cars.
