re: Repetitive engine oil leak from the tappet & timing belt covers Quote:
Originally Posted by akshay380 Can someone suggest what could have gone wrong? We can try replacing tappet cover and Cam seals(for leak inside Timing Belt cover) but I want to make sure its the culprit and not something else.
In my experience leaking covers tend to be due to the following:
- Use of inferior seals
- Incorrect torquing sequence
- Incorrect torque (no torque wrench used)
- Surfaces not cleaned properly
It seems an almost mundane task, replacing a seal. But a lot can go wrong if you do it to casually.
Make sure the engine is completely cooled down.
it is absolutely vital both surfaces are completely clean of any old sealing/gasket. The best instrument to check are your fingers and eyes. Run your finger across the total surface.
Make sure you are using a good seal/gasket. There is a reason why aftermarket seals/gaskets are cheap. They are often made of inferior materials and or don’t have a good fit.
Make sure you check the workshop manual on how to tighten the cover. There are two aspects to it. The sequence and the torque.
Again, without a workshop manual you will never know. But must covers are tightens as follows. Hand tighten all nuts/bolts. Then start applying, with a torque wrench, the correct torque, working from the bolts/nuts in the middle of the cover to the outside. Alternate both sides.
Some manufacturers actually specify torquing in two stages (e.g. typical 6-8 cylinder engines). On some cars you might have to re-torque these components after a short drive where the engines has the chance to warm up completely.
If all fails, some mechanics will apply some sealant paste to the gasket covers. I am not a huge fan. It makes for a messy job next time cleaning.
There is another reason why a cover might leak: if its warped. You can check that on a workbench or with a good long straight ruler or similar.
Good luck
Jeroen |
