Re: Braking problem in my Chevrolet Beat Dear Fellow Bhpians,
I am bumping up an old thread on the issue with Brake Master Cylinder as I am facing the same issue, though the car in this case is a 2018 Tiago XZ with 11.5 K kms on odometer.
I would humbly the request the mods to move it to separate thread on Tiago brakes, if deemed necessary.
The issue started about after a month after doing 4th full servicing at a multicar service station, prior to which all the services were done at Tata ASC and the quality was appalling to say the least. I took the car on daily errand and luckily while I was still under 20 Kph and about 500 mts from home, I applied brakes. The brake pedal simply sank till the bottom before there was any bite. Drove it back home cautiously and then to the Multi service station on weekend. The service advisor said that probably air was in the brake line, and it was not bleeded properly earlier. Brake bleeding and top up was done and the brake was good again.
Then after about 3 weeks, I took the Tiago and the same issue happened. As I had lost my faith in the previous Multicar outlet, drove to another one this time. They checked thoroughly for any leakage on all 4 wheels and other related areas and told that Master cylinder is faulty and would need to be replaced. As I didn't want to change such critical part anywhere other than Tata ASC, i told them to bleed and top up again so that I could take the car to ASC.
Initially the Senior Service Advisor at ASC was very skeptic when I explained the issue and told that I need the Master cylinder needs replacement. He said that it must be some other issue. But on telling him that I am member of team-bhp he gave weightage to my words and checked the car himself. He agreed that there was indeed an issue, but he would revert only after a thorough check.
Today he called to me and told me that they would replace the entire brake booster with Tandem Master Cylinder costing about 9K.
Could you please let me know if it is really required to change the Brake Booster with TMC or replacing the TMC alone suffices. Also the SA told me that Brake Booster and TMC are single unit, while on a spare parts portal i can see that both of them are available - TMC alone ( about 4K ) and TMC with Brake Booster ( about 9K ).
A quick revert would be highly appreciated as I need to revert to the ASC by today evening.
Thanks & Regards,
Javageek |
