Old 24th March 2007, 14:42   #1
Ground Clearance
Getz GLS has tyre specs as 175/70R13 and GLX (ABS+ ALLOYs) has 175/65R14. Does this mean that GLX has higher ground clearance of 0.5 inch?
cartech is offline
Old 24th March 2007, 14:53   #2
mobike008's Avatar
Thanked: 17,179 Times
70 as in 175/70 R13 is the section height of the tyre so when you choose 65 as in 175/65 R14, its lower profile which means the ground clearance reduces.
I just used logic to respond, i could be wrong.
mobike008 is offline
Old 24th March 2007, 15:07   #3
kpzen's Avatar
Thanked: 1,884 Times
Comparison of running radius of tyres
1. 175/70-13
radius of rim = 6.5x 25.4 = 165.1mm
sidewall of tyre = 0.70x 175 = 122.5mm
Running radius = radius of rim + sidewall hieght = 165.1 + 122.5 = 287.6
2. 175/65-14
radius of rim = 7x 25.4 = 177.8mm
sidewall of tyre = 0.65x175 =113.75mm
Running radius = radius of rim + sidewall hieght = 177.8 + 113.75 = 291.55
Difference in running radius of both tyres is the difference in ground clearance
175/65-14 will provide u with extra 4mm ground clearance
kpzen is online now   (2) Thanks
Old 24th March 2007, 15:10   #4
mobike008's Avatar
Good one Kpzen. how did you derive those figures of radius of rims and sidewall of tyres?
Old 24th March 2007, 15:16   #5
kpzen's Avatar
175/70-13
175 - section width of the tyre
70 - profile of the tyre(%age)
13 - rim size
sidewall of the tyre = (70/100) x 175 =122.5mm
kpzen is online now
Old 24th March 2007, 15:38   #6
Ram
Ram's Avatar
Thanked: 223 Times
kpzen, you're absolutely right.
mobike008, this is how it's computed!
So, the difference is 3.95 mm, which is IMHO, insignificant.
10,000 km of tire wear will shave off 2-3 mm of tread anyway!
Ram
[also ref: my post]
Ram is offline
Old 24th March 2007, 15:42   #7
KPZEN and RAM thanks for clarification. My doubts cleared.
cartech is offline
Old 24th March 2007, 19:49   #8
rishibravo's Avatar
Thanked: 12 Times
175/70-13
13 - rim size
Fundoo explaination. Now I dont have to refer to the tyre bible everytime i need to calculate this
rishibravo is offline
Old 10th December 2007, 20:13   #9
Can we increase the ground clearence of a car ? if yes how ? car in question is aveo , like to have the ground clearance which sx4 enjoys .
madaboutCARS is offline
Old 10th December 2007, 20:42   #10
kpzen's Avatar
Why do u want to increase the GC of Aveo which has good enough GC for our Indian roads??
kpzen is online now
Old 11th December 2007, 05:40   #11
Rehaan's Avatar
Thanked: 36,140 Times
Also try these threads :
http://www.team-bhp.com/forum/techni...-measured.html
http://www.team-bhp.com/forum/modifi...clearance.html
cya
R
Rehaan is offline
Old 11th December 2007, 10:30   #12
Thanked: 56 Times
1. 175/70-13
I am sorry, but i still didnt get it.
175 is the section width.
70% is the profile,
13 is the rim radius.
so then
"radius of rim = 6.5x 25.4 = 165.1mm"
is what radius and how is this getting calculated?
Appreciate explaining it a little more
amohit is offline
Old 11th December 2007, 10:49   #13
Rehaan's Avatar
Originally Posted by amohit View Post
so then
Not sure if i understand your doubt exactly, but...
6.5 (is half of 13", which is the rim diameter)
25.4 (is the multiplication to convert inches to mm)
the resultant answer (165.1mm) is the radius of only the wheel (without the tyre added to it)
cya
R
Rehaan is offline
Old 11th December 2007, 10:55   #14
Thanked: 56 Times
oh got it...earlier it was written 13 as radius...so got confused.
amohit is offline
Old 11th December 2007, 11:48   #15
kpzen's Avatar
13" is the rim diameter. Rest i think u have understood.
kpzen is online now
