Originally Posted by Rahul Bhalgat Hi Sen,
Please check the rear wheel alignment too. The following diagram shows an example of the effect of rear wheel misalignment.
Have the alignment shops seriously checked the rear wheel alignment or did they mainly focus on the front wheel, taking the rear wheel for granted? |
Thanks for this advice! Unfortunately, they checked the alignment of all 4 tires each time, so this was quickly ruled out.
Originally Posted by R2D2 Some cars will pull to the left on a road banked to drain rain water. Have you tried testing your car on other roads including those that are relatively flat to check if the car exhibits the same behavior? Some unexpected tram-lining maybe a pecularity due to the tyre tread design not a defect. |
Thanks for the advice! I tried it on every single road I normally commute on, and drove about 1000 kms in the last 5-6 days overall, so believe me, it's not the roads or the bank angles causing it. Tram lining doesn't seem to be the cause, I've felt that while driving before, didn't feel that way.
Originally Posted by R2D2 Also, don't expect the car to be travel in a perfect straight line at all times. There will be anomalies in the road, tyre, steering geometry that cause it to behave otherwise. You should be worried only if it pulls to the left on all roads which causes you to compensate using the steering wheel. That can cause driver fatigue. |
Yep, agreed and noted. The veering is very subtle, starts after 3-5 seconds usually around 60 kmph
Originally Posted by Kosfactor If you cannot drive at all even for a short distance with your hands off the wheel, then don't do a long trip on it. You are going to wear out the new tyres.(also check if all new tyres are mounted in the correct direction of rotation). Sometimes it's the cross winds on highway.
Go to an old and established alignment shop, have them test drive the vehicle and make necessary adjustments if needed, that should fix it. |
Thanks for the tips! The veering was very subtle in it's start as described above, wasn't much trouble fortunately on my trip to Bangalore, so we're good. Gonna have Madhu's look at it, although third time's the charm and it seems to have lessened after that last alignment, maybe the machine was better or it was a slight tire defect that got worn down after the 600 km highway run? (Heshbon alignment at VW Secunderabad Service, then a Hoffman/John Bean machine at Stunnerz Madhapur, Hyderabad, the last one was a John Bean at VW Palace Cross Mysore Road Service center). I'll never know.
Originally Posted by SS-Traveller Ah... I guess I misunderstood when you said... |
Sorry about my vague terminology, and thanks for your time! I'll go to Madhu's this week and hopefully have it sorted.
Originally Posted by Mr.Boss 1) Make sure Conti UC6 is designed for RHD. Tire design have some unique parameters for LHD & RHD (I leave to tire experts for better explanation) |
These Contis are "specifically designed for Indian conditions" I read in multiple places, leading me to the assumption that LHD tires were out of the equation, maybe I thought wrong. I'll have to check the tire specs and see if this could be potentially a headache to look at.
Originally Posted by Mr.Boss 2) Take support from either tire dealer or VW to have a swap analysis with OE tire. If the phenomena is still same, leave it to VW for swap analysis, root cause analysis and countermeasure.
If the issue is sorted out with OE tires, you have below choices
- Live with OE tire
- Swap with something else (other than Conti UC6)
- Play with alignment values to make the car go straight (this may have some after effects) |
Thanks for the idea, but unfortunately, I'm going to be stuck here for at least a month in Bangalore (potentially six months) so this option is a bit difficult. Maybe I'll let VW handle it to see if it's indeed a deeper-rooted problem, I've given two different service centers a chance to fix this at this point.
Originally Posted by ChoosetoCruze Gentle pulling over 200m sounds like a normal case of a gentle left slope inbuilt in the road.
Go ahead & book that test drive & compare it to your vehicle. |
Generally if it was just the road banking I'd be fine with it, but it seems to happen and visibly flat roads as well as slightly-right banked roads as well. I'll observe the issue and get a detailed alignment report from Madhu's, hopefully I find at least one answer for this peculiar albeit minor issue.
Thank you everyone for your time and suggestions.
