Hello! I recently bought a 2014 Honda Accord LX (2.4 I4) in Washington. It is a single owner vehicle with around 50,000 miles on it (low mileage for 7yrs!).
However, I noticed that when the AC is on, the twin cooling fans inbetween the engine and the radiator go on and off crazily (like every 20sec or so). I read on a couple of online forums that this was deliberately done by Honda to reduce load on the compressor.
Is this normal?
Get your radiator and ac condenser cleaned with a pressure washer. Repeated kicking of fans occurs because the condenser alone is not able to dissipate heat owing to dust accumulation.
Originally Posted by karthikbhat8923
(Post 5107932)
Is this normal? |
I think its completely OK. The thermostat is working and hence this behavior. You should be concerned if the fan doesn't turn on or is running in full speed all the time.
One of the cooling fan is normally commanded by engine coolant temperature while the other is commanded by the operation of the AC Compressor. Only in extreme conditions both fans run as a fail safe. So depending on the condition the fans turn on and off intermittently.
