Re: Hyundai Grand i10 Electrical Problems Quote:
Originally Posted by Capt.Ashu 2018 Hyundai Grand i10 Sportz AT.
1. Yesterday when she engaged reverse gear, the reverse camera did not switch on. After several failed attempts it switched on.
2. On reaching her destination, she turned off the car engine and removed the key but the radio did not switch off. She replaced the key and turned the accessories on - off a few times but it did not work. She then restarted the engine and turned it off, then the radio was finally off.
3. Couple of days ago, a few minutes after she locked the car, the hazard lights came on for sometime and then switched off again. |
Captain, I'm assuming that the car is able to start without any hesitation and that the cranking power is good - if yes, the battery has enough juice. However, given that the car is over 3 years old, please have the health of the battery checked, and do check for sulfation at the battery terminals.
I can suggest the following checks for the three issues you've highlighted:
1. Reverse camera display not on - Without starting the engine, please slot the gear in reverse and if the camera display doesn't turn on, please check if the reverse light is on? If the reverse light isn't on, the issue could be with the reverse switch wiring
2. Radio not switching off - the key barrel could be malfunctioning - there is a switch at the end of the key barrel called the body switch in which a wiring coupler is fitted - if your FNG has a good electrician, they could open that alone, clean the contacts put it back and see.
When the key is taken out of the barrel, is a click or khat sound heard everytime? If not, the key barrel is the culprit. A bit of WD40 spray into the barrel and then operating the barrel a few times will help
3. Hazard lights coming on for sometime - this happens when the security system senses a malfunction eg. one or more door unlocked. It can also happen when the circuit power gets reset
The one thing in common for all the three issues you've reported is the Body Control Module (BCM). If there is an intermittent low power supply issue there, one or more issues with on board electricals can occur.
