Charging a 12v DIY power bank from a car How to charge a 12v DIY power bank from a car ?
Recently, my son made a portable DIY lithium power bank with a 50 watt rated solar panel and a 130 watt rated PWM-based solar charge controller and this setup is working fine. However, we also want this power bank to be able to get recharged from the 12v sockets in my car.
And here lies the issue. The sockets in my car are rated at 180 watts at 12 volts DC. When the engine is on, its battery voltage is around 14.2 volts and the solar charge controller has no issues handling that. But the problem lies with the amount of current. From what we have seen, anything above 5 amperes at 14.2 volts causes the power bank's batteries to become warm with the added risk of the charge controller getting damaged since the car's 12v sockets can put out way more power. We obviously do not want any untoward incidents to happen. In case it was not obvious, we want to use the solar panel's input port on the charge controller to work as the input from the car's 12v socket when the solar panel is not connected to the charge controller. I am assuming that a 5 ampere DC fuse is going to be blown almost instantly when the 12v sockets in my car are connected to the solar panel's port on the solar charge controller.
So my question is that is there a way to restrict the flow of current to below 5 amperes irrespective of the voltage ? If yes and if there are multiple ways to do this then what would be the best approach ?
I request my fellow knowledgeable BHPians to please help and guide me. I have an Arts background and hence I am not too familiar with electronics even though I have spent a very large portion of my life fixing and maintaining our cars by ourselves. On the other hand, my son has a Science background with a specialization in Mathematics but even he is not too familiar with the nitty-gritty of electronics.
Waiting for your knowledgeable assistance |
