Originally Posted by vishy76 Mine didn't come in one piece. I am not even sure if the mechanic centered the clutch since I was not there when the GB was reinstalled. |
I used a short piece of an old gearbox input shaft as a centering tool. I put the shaft in first and bolted on the clutch pressure plate, getting the friction plate perfectly in the centre. I removed the shaft before bolting on the gearbox. Later on I got myself a universal tool
If the friction plate is not in the centre, the mechanic will have to force the gearbox in using the bolts, risking a bent input shaft. I have seen this being done once at a backyard workshop.
The gearbox if everything is alligned, should easily slide in without the use of force to mate with the engine.
If the shaft is bent you will be looking at problems in the future. It could damage your new clutch and cause bearing problems inside the gearbox.
You said earlier that he did not use a torque wrench. This has me wondering if he did the job according to the books.
I went back to your post and see that he has pulled out the output flange on the gearbox.
When this shaft is removed from the gearbox it has to be firmly pushed in to refit and connect the locking ring. When I removed mine, I had to help with a hammer to get it to lock. I am sure your problem lies here. I just cannot understand why he did this. Perhaps he is used to working with Toyotas without the locking ring where the shaft just slides into the gearbox.
Have this sorted out before things break.
He would never be able to push in the flange connected to the driveshaft. Go back to the shop and ask him to remove the driveshafts the proper way and make sure the flanges are locked in place before fitting the driveshafts. Your problems should go away
This is a gearbox with the driveshafts removed and I have marked the flange.
This your gearbox with the flange pulled out. You can clearly see that he has plugged the hole with paper.
Here is the driveshaft. Note that the inner joint is fitted with bolts.
Here is the flange and all the parts that he pulled out. A big No No. This has to be fitted first and the driveshaft bolted on to it. Otherwise it is impossible to get it all the way in to lock. Look underneath the car and look at the inner joint and take some clear pictures. Look for oil leaks!
