re: Abysmal mileage on a Tata Altroz 1.2L NA Petrol Quote:
Originally Posted by Nikhil Beke I must say I've been through the same dilemma few weeks back- whether my car has anything amiss-have logged similar concerns on Altroz iturbo thread few days back.
1. Unlike Diesel engines, petrol (NA/turbo) are going to show big variance in FE in city/Highway traffic.
2. Engines need to warm up before they work efficiently- if most of your trips are <8kms each, you can't expect a great efficiency.
3. Does your car offer autoAC? Do you use it often? It tends to cool the entire cabin to the set temperature, which is quite a drag in terms of performance/fuel efficiency. Try setting desired AC fan speed for short runs/when you're driving alone.
Thanks for your help. My trips are usually around >20km. I do use the auto AC often. Quote:
Originally Posted by Nikhil Beke Further, I suggest:
1. Check with a fellow Baleno owner with a similar driving pattern- you know the realistic figures to compare with (don't get disheartened further )
2. Do a long highway run: 100-odd kms and then check the FE. My iturbo gives 18-20kmpl on highways (fuelio figures).
The thread quoted above has enough ammunition for safe hypermiling: enjoy! | on the baleno reference. I am currently out on a ~300km round trip. Will log the FE and report back. Quote:
Originally Posted by Kosfactor ~ 12 kmpl is good for a vehicle that weights ~ 1000 kgs and that engine. The turbo variant will see single digit when traffic is heavy. Not everything will treat petrol like a Maruti would , but you win some, you lose some.
Enjoy the car and please remember , the more you drive the better it gets - car as well as you. 2600 kms in 10 months , I don't think you should worry about fuel cost at all. |
Ha ha, 2600kms in 10 months is a joke. I'd hopefully do better the next year Quote:
Originally Posted by GTO That engine is overworked in this car. Puny engines that are stressed never result in class-leading FE. That said, I think your numbers are decent for the weight of the car. |
Thanks, GTO. Quote:
Originally Posted by SoumenD 11kmpl from a 1.2L engine in Kolkata traffic is decent enough. I get that much from the Honda 1.2L iVtec in Bangalore. May I know what was your expectation? Did you believe the sales guy’s pitch who would have told 15kmpl+ while selling the car?
Petrol 1.2L engines from any brand realistically returns anything between 9-12kmpl in city depending on traffic conditions. Maruti might be a little better for obvious reasons. But rest are around that ballpark figure. |
Well, I used to believe the MID figure on altroz to be fairly accurate - it was when I tallied some time ago - so in my mind, the FE figure always hovered around 15kmpl - at least on highway runs. Never really paid attention to the fuelio logs. Thus, the surprise. Quote:
Originally Posted by shancz To give you a reality check about small petrol engines.
Our wagonR (2016) gives around 11-12kmpl in city with A/C and sedate driving, 14-15 without A/C, 17 kmpl on highways/empty city roads with minimal A/C.
Suggest to recheck your FE on highways.
The variance between your tankful and the MID isn't acceptable. I usually drive to at least half a tank before refilling to minimize errors while tanking up.
The mismatch between rpm and speed is usually the clutch but your car is too new to have that. But do try the same with A/C off and lesser loads to see how it behaves. |
Thanks shancz. My tests were with two people on board and AC on. The MID - real life mismatch is indeed surprising. Quote:
Originally Posted by ron82x3 This is the Mileage of my 2017 Grand i10 Asta Petrol 1.2
You should expect similar mileage in your car. I have also driven the car mostly in Kolkata.
You need not worry, even the power drop is due to the increase in rolling resistance of the tires which is more in a wet road.
I'd recommend to check your tire pressure once a week.
No need to worry about mileage, it's more than acceptable. |
Awesome of you to share your detailed FE logs. I however, still think the power drop is unusual - I can feel something's off. Earlier, I had a bad jump at 70KPH on a stretch of NH that had a missing chunk of tarmac and a considerable drop. The MID figures have dropped since that - similarly, the power issue has cropped up. So it could be that. At the very least, the rear right tyre has developed a slow leak - possibly from the wheel rim. I plan to get the wheels and the underbody checked. Quote:
Originally Posted by deathwalkr er am I missing something here? where is the abysmal mileage mentioned?
I drive a linea t jet so these numbers are like wow to me |
lol. Quote:
Originally Posted by SS80 Check the air filter in your car, if you drive in dusty conditions, it will clog sooner than expected. Try cleaning air filter for now and then see the difference. |
Thanks. The service center did clean the filter with compressed air. Not much perceptible difference tbh.
I am currently out on a trip and the MID shows ~15kmpl after 150km - this is with 30kph average speed. Will check the FE after fill up and report back. Separately, having driven ~150km today, I think it's not that the rpm - speed doesn't match, but that it takes longer than earlier to rev up - as if there's some resistance. I'll get this checked.
Thanks to all of you. |
