ECM To be replaced. Need some advice. Hi, This is my very first post so please bear with me. Car model
Toyota Corolla Altis V AT 2008 Background
The car was dormant for about a year as I was away from home. Problems it's having - Two out of four fuel injectors are not working.
- Can not go above 40kmph.
- Engine overheats in a few mins even with the radiator fan on and the engine temperature gauge shows normal.
- Jerks when at idle.
- Scan is only showing P2118 error
- Slight kick when put into D or R
I took it to a Trusted Mechanic here at Mallick Bazar area, Kolkata. The mechanic first checked the throttle body based on the error code and replaced the fuel injector with new ones then checked the cable from ECM to the fuel injector after that checked the ECM itself and said the ECM is faulty and can not be repaired and needs replacement. Solution
ECM to be replaced from another same Altis. Cost
20k with ECM programming Now I have some questions. - Is there any way for the ECM to be repaired?
- Is this a good price for a used ECM?
- Will my car work properly with the new ECM from an another car?
Any kind of advice would be helpful. |
