Old 14th October 2022, 20:31   #1
BMW Transmission Error | "Secure vehicle with parking brake when stationary"
Hello,
I am based in Pune and recently bought a pre-owned BMW and with few days of driving I got a message saying Transmission : Secure Vehicle with Parking Brake when Stationary. A quick check on google shows that this is a fairly known issue in BMW but quite a costly affair to fix. Apparently this is problem with gear shift assembly may cost a bomb if entire thing was to be replaced in service centre. Youtube videos talk about this being caused specifically by a broken spring but of course is a very involved process. I am putting this problem here to check if any one here has faced similar problem and what steps were taken to fix it.
BMW Transmission Error | "Secure vehicle with parking brake when stationary"-6b78ae78f84b484aa6be1c82d8d472e5_1_201_a.jpeg
Luxurylover is offline   (2) Thanks
Old 15th October 2022, 09:32   #2
Maverick5490's Avatar
Thanked: 2,008 Times
re: BMW Transmission Error | "Secure vehicle with parking brake when stationary"
Originally Posted by Luxurylover View Post
Hello,
What are the symptoms you are getting while driving? Is the vehicle jerking or not shifting to R/D? Open the bonnet and below the Left headlight is the transmission control unit. Check if there is rodent damage, could be one of the cause. Else unless you read the error codes cannot confirm what can be the issue. Alternatively, How old is the car and does it have service record at the dealer ship? you can push for replacement under goodwill.
Maverick5490 is offline   (7) Thanks
Old 15th October 2022, 11:21   #3
Got the error scanned and here is what we got. Shiftlock Solenoid : Selector lever wrongly not parked in P.
Quick read on internet says it’s a problem with spring. It’s 2017 model and out of warranty.
BMW Transmission Error | "Secure vehicle with parking brake when stationary"-02177240e9cf4475a30d110d03e1c4f4.jpeg
BMW Transmission Error | "Secure vehicle with parking brake when stationary"-723982cdd69642f1b53694e57e1c5aab.jpeg
Last edited by Luxurylover : 15th October 2022 at 11:25. Reason: Adding attachment
Luxurylover is offline   (3) Thanks
Old 15th October 2022, 11:23   #4
No symptoms as such. Just get this message when put in parking. I got this scanned and it’s says Shiftlock Solenoid : Selector lever not wrongly locked in P. Quick read on the Internet tells me it’s a common problem in BMW.
Luxurylover is offline   (1) Thanks
Old 28th October 2022, 11:05   #5
Re: BMW Transmission Error | "Secure vehicle with parking brake when stationary"
Seems to be a fairly simple part that broke. Try contacting a local Bmw specialist like Mechanix and explain the situation after you share the video. Another route might be finding an experienced mechanic in your area and showing him what needs to be done after you order the part on a reputed seller or from the Bmw spares department. I got my steering wheel upgraded on my F30 by a non-bmw mechanic after he looked at a clip like the one below. If all fails, try reaching out to your dealer to get an estimated quote. Or maybe getting it done along with another major service at a discount if they are willing to negotiate. For what its worth, your X1 should be bulletproof and doesn't have any known major issues. Good luck
bhavishya is offline
Old 28th October 2022, 18:35   #6
Hayek's Avatar
Thanked: 17,066 Times
First check if your battery is in order. Got similar (but not the same) errors from time to time - but the message would disappear after a while. Took it to the dealer and they found it was because the battery was not working and hence the iDrive indicators were giving errors. If you are getting an error but the car is running fine, this could be the problem
Hayek is offline
Old 19th December 2024, 17:05   #7
Hello,
Hi.
Were you able to sort out your issue? My car had the message pop up few days ago.
aypatel is offline
Old 25th April 2025, 19:31   #8
Thanked: 30 Times
Originally Posted by aypatel View Post
Hi.
Bumping up the thread. I got the same error today. Did anyone find a solution here
fatsoboy is offline
Old 22nd May 2025, 13:32   #9
I had to replace the entire gear shift assembly. Total cost, 85,000 at the dealer.
The part looks somewhat like this below:
https://www.ebay.com/itm/29706897227...tion=view_item
aypatel is offline
