Re: VW Polo GT TSI not cranking - ASC says DSG failure!! Hi, i once owned the same car, a 2016 Polo GT TSI with 60k kms which suffered exact same problem - Blinking P on shifter, no crank at the floor of Authorised VW Service center itself.
After replacing the battery, they first diagnosed it to be a faulty starter motor and the service center did a U-Turn after a week claiming the final diagnosis as DSG mechatronics failure which made no sense.
Finally Towed it to a FNG where it turned out to be faulty brake pedal sensor (Error code showed up in VCDS for the module) hence no crank since you need to press the brake while cranking the car, please do get that checked out before proceeding to any other repair.
