Hyundai i20 Turbo check engine light | DTC P007100 While driving my 2 year old i20 turbo 1.0 IMT with about 12k km on the odo, CEL comes on. Car is running flawlessly and giving good mileage.
Took it to Advaith Hyundai in Indiranagar (it was 5th February Sunday) where a technician connected the OBD and the error code was P007100. (Ambient Air temperature circuit range /performance)
He was clueless about what to do about it. He cleared the error code, and I didn't insist he do anything else, seeing his incompetence. Anyway he said if it happens again we will change the sensor.
I drove off and CEL did not come on again.
Till 28th February while I was driving Mysore to Bangalore when again the CEL lit up. Drove the rest of the 150 odd kms straight to Advaith Hyundai and same technician was there and this time the same DTC code showed up. This time he says we need time to check the sensor so leave the car here and we will get back to you. However, due to other reasons I couldn't, so he cleared the code again. And I carried on with my journey of another 160 kms in next 2 days without the light coming on or any other issues with the car.
The Ambient temperature sensor is located in front of the radiator and gives the information to ECU, which processes it further. This temperature info is also presented on the MID. Knowing this, I monitored the temperature regularly and it was quite accurate. So I'm at a loss to see how the sensor has failed. Moreover, if it has failed /loose connection, why does the CEL stay off after getting the DTC cleared?
Another thing, maybe a coincidence, both times the CEL came on shortly after filling in petrol. Not immediately but after a few kms.
Can anyone suggest my further course of action. Thanks
Reason: Spacing
