I have driven 7KM to my home after the 75K service of my Skoda Rapid 1.5Tdi.
The oil level is at half way mark
The service center states that they have filled 4.3 liters as billed. I stated that it has been so for all past services but the oil was close to top level on the dipstick (not midway as noted this time)
Am I over responding? Requesting guidance
Originally Posted by KANNURAN
(Post 5515589)
Am I over responding? Requesting guidance Attachment 2431276 |
First ensure that you are measuring the volume as mentioned in the owner's manual. On a cold engine, it may be equal to top level. I don't know how it is measured for you car.
Secondly, it is ok to have the oil anywhere in between the low and max level. Observe for a month or two, if the level goes down further, top up to max level.
(Post 5515589)
Hi, I have been in the same boat many a times,I have observed the same thing after every service , basically if they let the old oil drain out completely and refill, then 4.3 litres of oil filled will show uptill the half mark on the dip stick. Recently, I had a oil change and I had to topup about 300ml over 4.3 litres to bring the level on the max mark on the dipstick. So there is nothing to worry about. If you find the level touch the low mark you can top up about 500ml at that point. Relax and enjoy the drive.
(Post 5515589)
Hey i think you are confused. So the oil level measuring stick present in all cars will have the markings for minimum oil level that must be there in the oil reservoir and max oil level that should not be exceeded. Like how it is seen in this picture, oil level anywhere in between these 2 marks is totally fine. An oil level that's midway between the min and max marks doesn't say the oil is filled only half of the oil tank. You don't have anything to worry about.
An oil level below the min mark means you are risking engine/gear ox damage due to poor lubrication, and an oil level higher than max mark means you are risking blowing all the oil seals, leading to oil leaks into unwanted places for eg. Into a dry clutch system. So always have the oil level between max and min marks.;)
Could you confirm that you pulled the dipstick first thing in the morning, on a cold engine and one wipe down?
Regardless, it's not low. It's alright for driving and could be double confirmed with the absence of any check engine/oil lamps on the instrument binnacle.
Originally Posted by lemedico
(Post 5534589)
Regardless, it's not low. It's alright for driving and could be double confirmed with the absence of any check engine/oil lamps on the instrument binnacle. |
Neither the CEL or the oil lamp on your dashboard are an indication of the oil being a little low. The oil lamp is actuated by a pressure sensor. So it is technically not an oil low level indication but a low oil pressure indication. On most cars it won’t come on, until your oil level is dangerously low. Usually way below the low mark on the dipstick, often enough the oil level is so low it won’t show on the dipstick at all!
The CEL has nothing to do with the oil level at all. Although I could imagine if you would ignore a low oil pressure for long enough it might show up too. Just before the engine seizes!
I only know of a few cars that have an actual oil level indication, rather than an oil pressure. On some cars with an oil pressure gauge the gauge registers the oil level prior to engine start with the ignition switched on. As soon as you start it reads oil pressure. Had one like that decades ago on a Renault 25 I recall.
Jeroen
Thank you Sir.
Given that Skoda service centers use a precise 4.3 liters for refilling the Rapid 1.5tdi after a oil and filter change (stating it to be a stipulation from Skoda) and the resulting level only comes to less than half way up the dipstick, what is the SAFE LEVEL to maintain?
Should I top up for the level be closer to the top notch on the dipstick, or leave as is till the level dips further and then top up to the midway mark?
Thank you.
(Post 5535050)
It really doesn’t matter. Anywhere between the max and minimum mark on your dipstick is fine and ensures proper lubrication and protection for the engine.
Personally, I never add oil until the level gets close to the min level.
As all my cars are at least twenty years old I tend to keep the oil level usually below half and not near the max. Older engines tend to use some oil and the higher the oil level the more oil they tend to use.
So, do whatever makes you feel comfortable. Just make sure you follow the oil level check procedure as stated in the owners manual. Which usually means checking the oil level with the engine cold and the car sitting level.
Jeroen
