Hi BHPians,
This is my first post after becoming part of the community here but I have been regular reader of forum.
I bought new XUV700 P AT AX7L few months back and gave it for 1st free service in March'24 at around 800 km ODO.
I explained only 1 major issue to the SA before the service:
1. Noise from front wheels while starting from 0 on accelerator or while braking and moving during taking out of parking in the morning regularly. It always happens and read some other users also facing the same.
Other minor issue - Seat memory function was not functioning consistently all the time and sometimes would lose the memory.
He said he may update the softwares and it will be ok, for the noise he said it is due to moisture in brakes and he will clean the brakes. - Although I told him in Bangalore during summer months and in my parking area there is no moisture.
There was one O-ring coolant pipe replacement recall showing in system and SA said they will have to do a replacement as a regular recall process.
Now problem that got created after the service is on the gear shifting and power. Totally unexpected since they did not make any such changes as it was a simple 1st service.
The vehicle doesnt feel as smooth on accelerator and engine seems more under load especially in the initial 1,2,3 gears (it is automatic, just intuitively figured when gear shifting happens) mostly under 50 kmph, worst around 20-30 kmph when at 30 next gear shift usually happens. The RPM even goes uptill 3k for 2nd to 3rd shift and the engine revving sound increases but as much power is lacking.
Earlier I did not have to press on accelerator as hard, it was very soft and gear shifting was not noticeable. Driving feel was butter smooth.
Now there is a big change and that driving pleasure has gone.
The SA says they did not do anything, and their expert tried driving around with me and said everything is normal.
SA is not clearly saying what all software upgrades were made, he did mention ECU update was done. The service record log is no longer showing in the Mahindra app now.
Need guidance on how to get this rectified. I really wish to get it back to what it was. It is a big deal very noticeable and many times even limiting on the road not getting enough power as needed.
