Old 16th July 2024, 15:19   #1
pramodpk's Avatar
Thanked: 630 Times
Battery light stays on in the instrument cluster
The battery light stays on in my Ford Fiesta 1.6 petrol. The car is 14 years old and has done 1.26 Lakh KMS. Currently the car is at Ford service station. They checked the alternator and it seems to be fine. Now they are suspecting that there is an issue with the PCM (ECU). A new PCM will cost Rs 35 K. Is there anything else to check?
Thanks in advance.
pramodpk is offline   (1) Thanks
Old 16th July 2024, 16:02   #2
Thanked: 45 Times
re: Battery light stays on in the instrument cluster
Old Battery - Old Alternator; New Battery - Old Alternator; Old Battery - New Alternator; New Battery - New Alternator. This is the SOP to check as Battery and Alternator works both ways. If none of these work, check for all loose wiring, remove sensors - clean dirt - put back sensors. Check OBD.
Pretty sure Ford must have done all this before concluding a PCM error. But if it's worth 35k, then it's worth asking them to redo. Also, what are the fault codes? Is ECU itself showing a fault code? I know couple of cases where something as petty as dirt on the air mass flow sensor caused a check engine light and/or a battery light (possible short-circuit? Nobody knows!) But got resolved as with some cleaning. My fiesta was notorious for troubles with its Lambda (Oxygen) sensor. Worth a look!
Lastly, if ECU replacement is the last resort then it can be swapped. Although it is not advisable to reuse an old ECU (from an identical variant car), given your car is already 14 years old, it maybe worth a shot. ASS won't do it (obviously) but it can be done aftermarket. It can be reprogrammed to your VIN too. Again, not a 100% solid thing to do, but given the age of the car and the cost it can save (north of 20k!), it is definitely worth a shot.
TheVDR is offline   (2) Thanks
Old 16th July 2024, 16:37   #3
Thanked: 5,002 Times
Regardless of what symptoms you’re noticing, the battery light is telling you a simple truth: you have either battery or charging problems,
It can be any of this;
- A loose or corroded battery cable/terminal
- A problem with the alternator or voltage regulator (Overcharging/Undercharging, most Likely, have happened twice with me)
- Damaged cells inside the battery or low electrolyte (Check battery condition)
- Faulty wiring in the car's electric charging system (leaking current)
- Damaged fuse
Older the car more is the probability of the above issues.
But mostly nothing to do with ECU, plug in the OBD scanner to find out.
NomadSK is offline   (1) Thanks
Old 26th August 2024, 16:28   #4
Captain Slow's Avatar
Thanked: 2,203 Times
Re: Battery light stays on in the instrument cluster
Thanks in advance.
I have my doubts if this is faulty PCM (ECU). Noticing the same issue on my old car which has just a simple carburetor the battery light stays on.
I have replaced the
Alternator
Battery
Checked all the fuse!
Still it stays on, I will need to trouble shoot this further.
Captain Slow is offline
Old 26th August 2024, 16:33   #5
pramodpk's Avatar
Thanked: 630 Times
Originally Posted by Captain Slow View Post
I have my bouts if this is faulty PCM (ECU).
The car ECU (PCM) was replaced and it's fine now. Tried with a different, battery etc before replacing PCM.
pramodpk is offline   (2) Thanks
