Re: My 2008 Skoda Fabia’s AC stops cooling after 30 minutes or so Quote:
Originally Posted by zaiddroid
I have a vagcom cable and vcds lite too, is there a way to diagnose the relay problem through a computer without having to physically touch wiring? Can I DM you? Thanks |
You can do an output test using VCDS. But this really would not give you rightful results. If you want to try, go to Engine--> Output tests--> Sequential/Selective-->Control Circuit for Cooling Fan.
This will make your fan run but then, how long can it run cannot be gauged. We know for the fact that it is stopping post driving for a set duration. You may need to connect a battery maintainer to the battery and then check the same, as continuous running of the fan will drain the battery, plus we are not even replicating the control side of the fan. You may have to run the test several times in order to determine the fault, albeit there is no guarantee of the same. So VCDS will run the fan for you but will not replicate the situation. It would be good if you send me a scan of the vehicle through the cable. I will DM you, since you still do not have the option, and we may continue.
Another method to check the fan, this includes the splicing of wires, but it is a cheap way to test without any extended analysis. You need to tap in the power terminal of the module, this can be determined by wiring diagram as to which side is control, power and ground. Once tapped in, you may connect a test light in parallel, and then route it all the way inside the cabin, and connect a known good ground. You can then drive the vehicle and as soon as the controller triggers the fan to turn on, the test light will light up. You should continue to drive until the issue comes, and when the issue comes the test light would not light up, and without switching off the engine or making any changes to existing conditions, you should go and check the power side of the fan control module which comes from the wiring harness, the diagram needs to be there with you for this. Take the same test light and then check if there is power supply to the control module itself. If there is still power supply to the module, then you can conclude that the module is indeed faulty, and you can then restart the vehicle and again the test light will glow. It is a long process, but will save a lot of money and no need of looking in other wirings. If all this does not happen then one needs to do more investigation.
Many would suggest, you should monitor the MVB under the engine for cooling fan activation. But I have already tried it in my case and it does not help. Hence the method.
Hope you understand what I am trying to convey.
Happy Motoring! |
