Pulse plugs incorporate a pulse circuit, which stores incoming electrical energy from the ignition system and releases the stored energy in a powerful pulse of power. Instead of 50 watts of peak power typical of all spark plugs, pulse plugs deliver up to 1 million watts of peak power. |
When the ignition signal is sent to a traditional spark plug, it begins to ionize the spark gap. This means that the voltage builds in the gap until a spark can be formed. During this ionization phase, which lasts about 5 millionths of a second, the incoming voltage (which has nowhere to go) heats up ignition components including the spark plug. This is wasted energy. When the ignition voltage overcomes the resistance in the spark gap, the spark is created with an initial discharge of approximately 50 watts. Once created, the spark resides between the electrodes at very low power for over a period of 30 millionths of a second. What is different about a pulse plug is that instead of heating ignition parts during the ionization phase, this energy is stored in the integral circuit inside the pulse plug. When the ignition power overcomes the resistance in the spark gap, the pulse circuit discharges all of its accumulated power - 1 million watts - in 2 billionths of a second! |
Enerpulse is headquartered in Albuquerque, New Mexico. We're a 10-year old company that specializes in developing environmentally friendly ignition products through the application of pulse power technology. With the assistance of Sandia National Laboratories in Albuquerque, we developed Pulstar™ to increase the peak power of the spark by 20,000 times and ignite gasoline in the engine's cylinder more completely, with less cycle-to-cycle variation. The result is more engine torque, more horsepower and better fuel economy |
Originally Posted by Jason Alright, I actually tried these plugs. I have a smoother idle, and on the dyno I have 7 hp increase. My old plugs were the Bosch +4 in an H22A. 7 hp is only about 3-4% though on my engine. Fuel economy I saw nothing. Its hard to tell if the plugs actually did this though. New NGK R plugs might have done this as well. Or air temp could have done that change too. But 100$ for 4 plugs isnt worth it. |
The revolutionary design of FireStorm spark plugs creates an electric plasma that fills the entire combustion chamber like a firestorm. It allows you to take an internal combustion engine from the standard 14.7:1 air-to-fuel ratio to an incredibly lean 24:1. At this ratio, all the air/fuel mixture is burned much more efficiently without increasing heat, thus giving an engine more power and fuel economy while creating much less pollution. That's the good news The bad news is that you can't buy a set of FireStorm spark plugs anywhere right now. No spark plug company wants to make them. Robert Krupa is no stranger to the way the automotive industry and spark plug industry operate. He has worked as a technician, then as an engineer for GM and Ford. |
Originally Posted by Sankar
(Post 567147)
Hey guys, i stumbled upon this on the net. Pulstar plugs are supposed to be the next generation in spark plugs technology. https://www.pulstarplug.com Guys what's your thoughts on this? |
Originally Posted by arjun.r
(Post 1074554)
1MW from a sparkplug...? I'm somewhat confused, but is 1MW a measurable fraction of the power generated at an Electricity Generation Plant??? |
