Originally Posted by BlackPearl Could you please throw some light on choosing between spacers and negative offset alloys as I understand both would make the wheels protrude a bit more than stock? |
What matters in suspension geometry and the corresponding additional loads due to the extended moment arm, is where the wheel center is located. With the spacers and the negative off-set wheels this remains the same, assuming the offset is the same.
However, the spacer is an additional part (additional chances of failiure), and if you can do away with it (negative off-set wheels), that would be the best option. I wanted stock-but-different looks hence the option of spacers. Quote:
Originally Posted by sharkashwa Keep in mind that with spacers, the lug bolts may need to be longer which also adds more bending loads and corresponding stresses to the components. ... |
Not necessarly. Properly engineered spacers are usually hub centric and need to be bolted on to the vehicle first, then wheels are bolted on the additional lugs on the spacer. Total 6 holes and 6 lugs in case of the Endeavor. Quote:
Originally Posted by man_of_steel Very debatable topic, but I am with you on this!  .
Good ones from reputed brands are pretty expensive and 2. I just love the OE alloys of the PS. They look so damn good to be stored away. |
This is how a Pajero Sport or an SUV is supposed to look man. Great looking truck there Quote:
- Steering has become a bit harder noticeably. But the PS already has a hard one and doesn't affect me much. The steering box will be able to take the extra load I am sure
- Feedback and kickbacks from slight undulations on trails has become more noticeable but nothing that's unacceptable
Some pics of mine in the current form with the 30mm spacers front and back and tyres upsized to the next size. Even after some research and convincing myself to go with the spacers, the plan was to install them first and remove it at the first sign of any trouble. But now close to 7k kms later, I am loving the improved stance of the PS and the lugnuts are in the same torque where I left it to be. Also, no steering vibration at triple digit cruising too. There was a slight rubbing in the inside wheel cladding at full lock which was taken care of with a heat gun without cutting the cladding.
Excellent. This is what I wanted to know. Thanks. Quote:
Originally Posted by FiestaST ..
I retorque my wheels every 2000-3000miles and before every long drive.
Hi, whats the performance degradation/enhancement you see in the Mini after installing the spacers? And what is the off-set?
Reason: Merged consecutive posts.
