Originally Posted by sbasak
(Post 590512)
Alto 1.1 http://img96.imageshack.us/img96/421...gine7rz0hv.jpg For Swift [post #1], there isn't a scale on either axis! |
Originally Posted by cyneverdie
(Post 600627)
to: akshay 2 okay in the autocar oct 07 issue top speed of the petrol swift is 174 : 160 for the diesel 0-100 12.29 ?wonder on what tires in which circumstances? okay in other mags which i dont have on me now:- i have seen "top speed 160 ' for the petrol swift always laughed : put it down to the mag s poor quality research or something but yeah man go figure check out the figure in top gear all me friends who have access to them are individually canned right now cy ps i hit 180 on the expressway when my car had 900 km on the odo - with my girlfriend in the car no mods only tires no redlines although did it in 4 gears i think super smooth + only 8.4 ish kmph speedo error |
Originally Posted by akshay1234
(Post 602657)
8.4 is alot of speedo error. your tyres are smaller because 195/60 is smaller than the recommended 195/65 for the swift. hence the speedo error. |
(Post 602890)
the swift speedo reads ideally perfect at 185/70 r 14 thats what maruti told me many times 195/65 is what people recommend and the speedo is not tuned for that you will get slight speedo error with this size with 195/60 r 14 i get a 4.4 kmph diff at 100 kmph so if my speedo showed 182-3 i was doing 172 ish are you trying to tell me the swift only goes till 160? peace cy |
(Post 603258)
Cy - did i ever say that the swift did only 160? i did NOT. all i said was that your car would be showing you a higher speed than you actually did because of the smaller tyres. you could have been doing 170 and your speedo would have showed 177 or so. infact i dont believe half of the top speeds mags give. they probably dont test them and just predict the figures. |
Originally Posted by sreenivass
(Post 622838)
195/65-14 seems to be a good up size with less than 1% error compared to stock 185/70-14. 195/65-14 seems to be giving more speedo error like -4%. Reference Tire size calculator There is no real point of disagreement here. |
