Airlock Problem
https://www.team-bhp.com/forum/technical-stuff/30705-airlock-problem.html)
Hi
I have purchased new Indica TC DLG model. From beginning onwards I faced problem with starting my car if I staying idle for more than 5 hrs. I contact my dealer and informed to this. They did something..!!!. Now I solved little bit earlier problem. But if I stay a day idle in cooling environment/ rainy, again I faced airlock problem. So I manuly pumped and getting started. Is this problem with all India TC cars or only my car, I dont know?. If anybody faced same issue, lets share to everybody.
Not heard of this as a common issue, there is some leak somewhere from where AIR is coming in the line.
There certainly is a air leak in the fuel supply line or else this wouldn't have happened. Whe you pump manually then you slowly remove the air from the lines and the vehicle starts.
Please check if the 'O' rings of diesel filter unit are properlu seated and tightened.
Originally Posted by yemshivakumar
(Post 611428)
Hi
I have purchased new Indica TC DLG model. From beginning onwards I faced problem with starting my car if I staying idle for more than 5 hrs. I contact my dealer and informed to this. They did something..!!!. Now I solved little bit earlier problem. But if I stay a day idle in cooling environment/ rainy, again I faced airlock problem. So I manuly pumped and getting started. Is this problem with all India TC cars or only my car, I dont know?. If anybody faced same issue, lets share to everybody. |
It should not happen unless you run out of fuel or there is a leak in the lines. Certainly not in a new car. Get the O-Ring checked.
If its a new car, it should be under warranty! Insist to the service people to have this rectified. Shouldn't be happening. It's not a common issue.
Leakage in the air lines seems to be a possible reason.
cya
A
Somethings wrong with ur FIP.
