Hi
Friends, i own a 2001 model MPFI esteem VX...i ve jus bought it recently
the cars running fine but thers one small problem..
ocassionally wen u start the car the rpm goes up to 1k or more wen in neutral n stays ther..so while drivin if u leave the accel 2 ..the car keeps movin ahead wid good enuf speed..which cn b dangerous in traffic..
somtimes this is gone wen i restart my car..wid everythn becomin normal n rpm remainin less than 1k in neutral..i ve shown it to a couple of mechanics who did some tuning n said it ws done..bt while driving i steel feel that the engine is fast...plz help me out as to what i cn do..
thnx
Note from the Team-BHP Support Staff : Slang and SMS Language are STRICTLY prohibited on Team-BHP. Please type in full and proper English for the benefit of other community members.
We advise you to read the Announcements and Board Rules section before proceeding any further.
Check the Throttle, clean if required...I think the adjustment of the Throttle valve needs to be done.
had same problem in my zen till yesterday.got the throttle body cleaned today and that solved :)
actually, today even i noticed the same problem in my 3 months old esteem. When i cold start the car, the rpm goes to 1500. then after a min settles down to 900+
I guess got to get it checked next time i go for service.
Originally Posted by amohit
(Post 678379)
Regards, |
thats not a problem. it would be high when you cold start a car so that it warms up quickly. after warming up it settles back down.
(Post 678379)
Regards, |
This is not a problem at all. All mpfi engines are set like that. In cold starts, they tend to idle at higher rpms & settle down to 900 rpm after a while whereas a carb engine can be made to idle even at 500-600 rpm, please do not compare these two. :)
(Post 678379)
Regards, |
It is all controlled by the ECU. Till the engine has reached a certain revs or maybe temp it will stay there. But after a very short drive it gets settled down. Nothing to worry here, its normal.
As others has put it, this is not a problem at all. Even my previous Wagon R was behaving the same way and now the Ikon is also same. This is the normal idling rpm when cold started. It settles down after about 5~10 mins running. Hence do not worry about this.
oh thank god!
all this time I had started thinking i'm wasting extra few ml of Shell Super every time I start my baby :)
dont worry guys. its very normal and delibrate.for every cold start all car that are ecu controlled have a concept of auto choke wherein a very rich mixture is injected to avoid dry run and to get that initial temp quickly. this settles within 5-15 sec depending on engine temp the sensors sense.
Originally Posted by snaronikar
(Post 679114)
As others has put it, this is not a problem at all. Even my previous Wagon R was behaving the same way and now the Ikon is also same. This is the normal idling rpm when cold started. It settles down after about 5~10 mins running. Hence do not worry about this. |
I agree. Even my petrol Fiesta has similar traits.
There is valve for the coolant at the connector that connects the coolant hose to the engine. The valve may be bad not closing or may have been removed as mechanics remove it if it is not working properly. I have the same issue on my esteem it was overheating as the valve was bad so i removed it but havent found the time to look for the missing valve. The valve stops the coolant flow when it is not needed. You may also find that the car is taking more time to warm up than normal that is due to excess coolant flowing through the engine.
Originally Posted by schumi2508
(Post 677563)
Hi
thnx Note from the Team-BHP Support Staff : Slang and SMS Language are STRICTLY prohibited on Team-BHP. Please type in full and proper English for the benefit of other community members. We advise you to read the Announcements and Board Rules section before proceeding any further. |
hello
CHECK UR IDEAL CONTROLL VALVE
This is common with 2001 model esteems the rpm comes down when the engine heats up.
HI, please take ur car to a authorised workshop and ask them to do a rpm control test by a tech2 diagnostic equipment. If the engine does not respond to the comand of tech2 gradualy and responds with jerks then it is time to replace the I.A.C valve,no wonder how much u try to clean the throtle body will not help. Actualy in this rpm test the I.A.C duty is changed tmporarily to which the engine response should be linear.:)
(Post 677563)
Hi
