Old 23rd December 2008, 11:55   #1
Thanked: 331 Times
How does TAP (Timing Advance Processor) work?
I own a baleno altura, cng fitted with lamda. Obviously the car struggles @ low rpm, it isn't fun to drive & i miss the petrol feel; the distance to be covered being so much that i cannot afford the luxury of petrol.
I've been reading a lot about TAP but have never exactly figured out what it does. Can please give me a detailed review/explanation. How much it costs?
Where from in south delhi? advantages/disadvantages?
I would be grateful
Additional info.
Car model-Baleno altura
cng-12/14kg(not sure) with lamda,
It's the kind where u accelerate to 4 rpm(ish) and cng switches on.
Engine malfunction light sometimes comes on around 70.
An advanced thankyou.This is a project i'm dying to undertake. Cheers
sukrit7 is offline
Old 23rd December 2008, 16:13   #2
ask77's Avatar
Thanked: 25 Times
Due to the fact that natural gas has different thermodynamic properties from petrol, the timing must be modified in order to adapt the engine to CNG fuel . CNG is slow burner and has a very high octane rating of 110 as compared to 87 of petrol. A timing advance processor induces the ecu into advancing the timing by altering the MAP sensor signal which is used by ECU to determine the spark timing . All this results in much better driveability of CNG cars fitted with TAP. In my opinion both Lambda and TAP are necessary for CNG cars .
ask77 is offline
Old 23rd December 2008, 16:58   #3
Thanked: 331 Times
thankyou. Any idea about the following.
Cost?
comparison with petrol performance ?
sukrit7 is offline
Old 23rd December 2008, 17:18   #4
Cost?
In Delhi, it would cost around Rs. 2500.
My car (WagonR) has been installed with lambda and TAP since conversion - and the power /pickup is almost the same as in Petrol.
Khandelwal is offline
Old 23rd December 2008, 18:26   #5
Thanked: 331 Times
@Khandelwal- Thanku, where in delhi? Is your's a closed loop or an open loop system
How do you find out?
sukrit7 is offline
Old 23rd December 2008, 19:26   #6
arpandiv's Avatar
Thanked: 62 Times
just a passing thought but has anyone tried connecting a TAP to a normal (petrol ) car and seeing if there is any difference in performance?
arpandiv is offline
Old 23rd December 2008, 19:41   #7
Thanked: 11 Times
Originally Posted by arpandiv View Post
just a passing thought but has anyone tried connecting a TAP to a normal (Petrol) car and seeing if there is any difference in performance?
I doubt whether the same can be connected to a normal Petrol car. Its a kitted car's device.
As for the price / availability of TAP, the price varies from about Rs. 1K to Rs. 3K (Chinese / Italian). I suggest you opt for a decent one. As for availability, you can go to AA Transfuels at G T Road Industrial Area (near Nanak Piu Gurudwara). Its near Ashok Vihar in North Delhi. You can PM me for further details.
He is a very trusted fitter and my friend has got his three cars kitted from him. Delighted with the service experience and performance.
WanderNomad is offline
Old 23rd December 2008, 19:45   #8
ask77's Avatar
Thanked: 25 Times
Lambda means closed loop. without lambda it is open loop. lambda takes input from the oxygen sensor ( lambda ) and the throttle position sensor to regulate the quantity of gas going into the engine intake thereby controlling the emission of the car . It has to be fitted by an expert since it has to initially programmed and properly calibrated.
ask77 is offline
Old 23rd December 2008, 21:50   #9
Thanked: 331 Times
Thanku all for your prompt replies.
@WanderNomad- I will pm u for details, if required. Thankyou.
I'll get the best one, money isn't a problem.
Another question, this improves fuel efficiency or the other way.
sukrit7 is offline
Old 24th December 2008, 10:02   #10
IMO, with Lambda, it becomes a closed loop.
Same here.
I have got my car converted from the same fitter. My vote goes out for him. Good experience and knowledge.
PM me for his number.
I have clocked more than 11K Km after CNG conversion.
My car's FE figures on CNG (per KG) are as below
Highways: ~22 KM (With AC) ~23 (w/o AC)
City: ~19KM (with/without AC)
Old 24th December 2008, 16:51   #11
Thanked: 331 Times
Thankyou khandelwal. Which car is this?
sukrit7 is offline
Old 24th December 2008, 17:11   #12
Check my previous post - Its WagonR.
Old 19th October 2010, 14:25   #13
9thsphinx's Avatar
Thanked: 549 Times
Does anyone in Mumbai/Delhi know where can I source Italian brand TAP's? Not the Chinese ones. Any help or contact details is highly appreciated.
9thsphinx is offline
Old 1st April 2020, 02:03   #14
HimuraKenshin's Avatar
Thanked: 329 Times
Re: How does TAP (Timing Advance Processor) work?
bumping up this old thread:
From what i've noticed, most sequential kits, have a crank position based timing advancer and other cars with venturi based kits, have a TPS/MAP based timing advancer. Just wanted to know, if the TPS based module can be installed in a sequential kit car.
HimuraKenshin is offline
