Old 20th February 2009, 23:42   #1
Raccoon's Avatar
Thanked: 116 Times
How to get rid of oil paint from tyres?
Whats the best way to get oil paint (white colour) off tyres with the least damage and fuss?
My dad got this bright idea of painting the vehicle number on the tyres. Can't stand it & want to get rid of it asap.
Anybody has any ideas?
Thanks in advance.
Raccoon is offline
Old 21st February 2009, 01:45   #2
ImmortalZ's Avatar
Thanked: 601 Times
Did you try tireshine?
ImmortalZ is offline
Old 21st February 2009, 02:07   #3
v1p3r's Avatar
Thanked: 7,505 Times
Infractions: 0/1 (7)
Should wear off with a vigorous scrub. Worst case, use a bit of acetone, though I have no idea how that'll react with the rubber.
v1p3r is offline
Old 21st February 2009, 02:27   #4
Raccoon's Avatar
Thanked: 116 Times
Tyreshine? Will have to find and buy it. Never tried it.
Acetone?? I think that will react very badly with the rubber. Dont wanna damage the new tyres...
Think something like diesel or WD40 might be worth a try? But again I don't know if it will adversely affect the tyres in any way...
Raccoon is offline
Old 21st February 2009, 02:51   #5
akshay4587's Avatar
Thanked: 4,722 Times
I dont think any tyre shine/care products are gonna help.
Acetone may react with rubber.
how about petrol?
akshay4587 is offline
Old 21st February 2009, 09:30   #6
BenjiRoss's Avatar
Thanked: 1,335 Times
Was just toying with the idea of nail polish remover - but have no idea what it contains!
(Some are acetone free)
Another idea - how about a tire rotation to get the painted part on the inner side.
BenjiRoss is offline
Old 21st February 2009, 11:33   #7
Thanked: 463 Times
You can try using diesel or paint thinner.
dadu is offline
Old 21st February 2009, 11:35   #8
mukeshgoel's Avatar
Thanked: 2,412 Times
Just an idea, why not put black paint on that white paint.
mukeshgoel is offline
Old 21st February 2009, 12:04   #9
Thanked: 463 Times
It will wear off in few months and when one is comfortable using paint, should be comfortable using thinner too (paint contains certain level of thinner).
dadu is offline
Old 21st February 2009, 14:25   #10
iraghava's Avatar
Thanked: 281 Times
Paint thinner should do the trick. Don't apply it directly, rather soak a clean cloth & then use it to wipe the paint off.
iraghava is offline
Old 21st February 2009, 15:05   #11
Raccoon's Avatar
Thanked: 116 Times
Thanks a heap for all the responses guys...
I read on the WD40 site FAQs that its ok to use on rubber... so I tried it, and got partial success. I think what I should try next is a pressure wash. I think I should have tried that 1st... but since it cant be done at home, I tried WD40. If pressure washing dosen't do the job, I think I'll try diesel... will have to go get it in a bottle. Idea is to try the least harmful things 1st... don't wanna damage the new rubber.
Gosh, thats toooooooooooooo much trouble! And would rather not tinker with it unless its absolutely necessary.
Yes, I think I'll try diesel. What is paint thinner called exactly? I guess I'll get it only in paint shops?
Thought of this, but I think it will still look bad if looked at closely. Also, oil paint might not be good for the rubber to begin with... so putting more of it might not be the best idea.
Raccoon is offline
Old 21st February 2009, 15:33   #12
Thanked: 4,910 Times
um, if they are not assymetric tyres, why not just turn the tyres around on the rims, so that the sidewalls with the markings are on the inside
greenhorn is offline
Old 21st February 2009, 16:06   #13
Raccoon's Avatar
Thanked: 116 Times
^^^As I said - that would be too much trouble... and tinkering. Would think of that as a last resort.
Raccoon is offline
Old 21st February 2009, 23:49   #14
Thanked: 727 Times
take a scrotch bright and rin bar. a towel type cloth.
Rub gently in circular fashion along with little warm water.
SirAlec is offline
Old 21st February 2009, 23:56   #15
ported_head's Avatar
Thanked: 21 Times
Try using brake oil.
ported_head is offline
