Team-BHP - F10D/F8D Engine Valve Clearance Adjustment
-   -   F10D/F8D Engine Valve Clearance Adjustment (https://www.team-bhp.com/forum/technical-stuff/54135-f10d-f8d-engine-valve-clearance-adjustment.html)
Hello there,
I have absolutely no idea what valve clearance this engine requires. I somebody knows the values or can even give advise or images, this would help me a lot. I haven't touched the engine so far.
Greetings
dont try to adjust the valve clearances if the engine is not making any sound or having any problem. how much have you done on the ODO?
if at all you are suspecting loose valves please take your wagonr/alto i.e F10D/F8D to maruti authorised service centre.
generally there are different values for valve clearances for cold and hot engines. but its safer to get them adjusted on cold engine.
1. how much it has clocked.
2. when is the last time you did this.
3.Do you have all the tools like feeler guage, tool box etc.
PS: Please do remember an ol' saying 'If ain't broke don't fix it'. That goes 100% with automobiles.
anyway here are the data. Its of F8B. Its 0.13-0.18 mm. 0.005-0.007 inch. Ideal is somewhere in between like 0.006inch. F8D is also same.
Well, thank you for the help. Funny, that the valve clearance is the same as with the old engine. Unusual. You are absolutely sure?
I will make myself to get it done in the next weeks.
It has 89.000 km; Next scheduled adjustment is by 90.000 km.
I bought it with 80.000 km, so I can only guess, when it was done before. I don't trust the dealers completely. Maybe ist has never been adjusted.
I think, it is prudent to do the adjustment before problems start. You may hear loose valves, but you won' hear too tight ones. And less clearance is dangerous for the engine. The valves may burn. I know that from motorcycles. The only maintanance you have to do apart from oil change is adjusting the valves. Oh, and maybe the brakes.
If I wanted to go to a dealer, I wouldn't have asked. :) I have made too many bad experiences with their work. It always cost a lot of money, but it is not always worth it.
If one has the tools, the time and some knowledge about the carspecs, it can be done by oneself.
Good for you ! The F8D & F10D are simple enough that most of the maintenance can be done at home, if you have the right tools that is :)
Yes, SirAlec's right, for the F10D...
F10D/F8D Engine Valve Clearance Adjustment-f10d_valve_lash.jpg
And for the F8D...
F10D/F8D Engine Valve Clearance Adjustment-f8d_valve_lash.jpg
You guys are great.
When I have done this and the timing belt and the oil change, I can run the car without thinking about possible engine damage.
PS: The clutch failed at 87.000 km. Not to blame the car. The pre-owner drove it only in town.
Originally Posted by Osterei (Post 1190375)
You guys are great.
dont blame the pre-owner too. 87000 is a very great figure for a maruti clutch.
Hello,
I have a 2009 Wagon R done 39000 kms. It is not making any strange sounds, but the fuel efficiency has dropped to 10 kmpl in Mumbai driving. Does it require a tappet setting considering age and kms?
Will tappet setting improve fuel efficiency?
Originally Posted by kavesh55 (Post 5261613)
Hello,
Check your air filter, replace if not done so in a while. Replace fuel filter, check brakes for brake binding.
At such low kms you do not need tappet adjustment.
Add some petrol additive and take it for a long drive. Sometimes continuous city driving causes carbon accumulation. With the additive the injectors etc should get cleaned and replenish any lost performance.
Sorry to dig an old grave. I have a 2008 Maruti Zen Estilo with an F10D engine. It has done about 52000 original kilometers on the ODO. I am currently not facing any issues with the engine except for a slight reduction in mileage (it could very well be a placebo). But I just wanted to know if it would be a good idea to adjust my valves at this mileage. I also wanted to know, what will be the signs of an engine that needs valve clearance. For loose valves, it's easy to understand from the ticking sound. What if my valves have become tight?
