Old 24th June 2005, 14:12   #1
Is My 99 Safari Turbocharged With Intercooler??
Hi Guys, I Have A 99 Tata Safari, I Knw It Is Turocharged, But I Do Not Knw If Its A Intercooler.
How Much Difference It Makes Between N Intercooler N A Non Intercooler? What Is The Difference??
If Mine Is Not An Intercooler Can I Convert Into It??
Amit
shahmotors is offline
Old 24th June 2005, 14:22   #2
SUV
SUV's Avatar
Tata Safari has a Intercooler
Hi Shahmotors
All Tata Safari's from the day of its Launch had Intercooler. The intercooler help the Turbo breathe Cold air whcih is more dense and inturn increases the power output by burning the fuel far better than a Non Intercooled engine.
TATA's are known for extracting maximum power out of their engine's.
Cold Air is more dense than hot air ..
SUV is offline
Old 24th June 2005, 14:44   #3
revtech's Avatar
Thanked: 39 Times
Turbochargers are a type of forced induction system. They compress the air flowing into the engine.The advantage of compressing the air is that it lets the engine squeeze more air into a cylinder, and more air means that more fuel can be added. Therefore, you get more power .
and as SUV said the intercooler gets in cold air which helps in more fuel being burnt therefore more power.
but can a turbo charged car not have an intercooler i thought they were interrelated and all turbocharged cars have to have an intercooler.
Rev
revtech is offline
Old 24th June 2005, 14:59   #4
Psycho's Avatar
Thanked: 111 Times
You can run a car without an intercooler however most of them do come with intercoolers. Intercoolers come in 2 main types air to air and water to air.
Water, Methanol, NoS injection is another method of reducing charge temparature.
Another weird thing the need for an intercooler also depends on where the turbo is mounted. Typically turbo's mounted on manifold's have the highest charge temp's whereas remote mounted systems typically have a lower charge temp.
Psycho is offline
Old 24th June 2005, 15:29   #5
Thanked: 322,365 Times
The early Tata Indigos were turbo'ed but without an intercooler
GTO is offline
Old 24th June 2005, 17:42   #6
revtech's Avatar
Thanked: 39 Times
ok cleared out some doubts.thanx Physco and GTO ...
Rev
revtech is offline
Old 24th June 2005, 20:25   #7
there can definately be turbo's without intercoolers like my jeep's isuzu engine is turocharged but it doesnt have an intercooler although the ones with intercoolers are more effective
Shrikar is offline
Old 26th June 2005, 10:03   #8
thanx guys, now 1 thing is for sure that there can be a turbocharger without intercooler.
so i doubt the early 99 safari had an intercooler.
if anybody knows for sure, pls tell
amit
Old 26th June 2005, 10:31   #9
Thanked: 705 Times
Every single Safari ever made, had an intercooler. Its right in front next to the radiator.
jyobeb is offline
Old 26th June 2005, 10:34   #10
Thanked: 705 Times
Oh and by the way, the Indigo still does not have an intercooler.
jyobeb is offline
Old 26th June 2005, 11:33   #11
DCEite's Avatar
Thanked: 3,484 Times
the new Indigo TDI has the intercooler
DCEite is offline
Old 13th May 2007, 19:38   #12
Proxima's Avatar
Thanked: 385 Times
I dont think the 99 Safari comes with an Intercooler.
Proxima is offline
Old 13th May 2007, 19:47   #13
pugram's Avatar
Thanked: 209 Times
The Indigo TDI and the Indica Turbo DLG / DLX models have intercoolers.
pugram is offline
Old 13th May 2007, 19:50   #14
Proxima's Avatar
Thanked: 385 Times
Correct, and the Indica DLS and DLE have only turbos, not intercoolers
Proxima is offline
Old 15th May 2007, 01:54   #15
Godfather's Avatar
Thanked: 71 Times
It has to have the intercooler.. Look for it next to the radiator. Will be mounter length wise.. .
Godfather
Godfather is offline
