Hi guys,
My 12 yr old m800 (carb) fuel guage seems to fluctuate ie it moves sharply to "E" when i drive it the car hard say 4000-5000 rpm in second gear.
I had just recently changed the fuel guage meter but the problem had persisted even before the guage was change.Only now what happens is
i put in fuel woth 100 bucks ,the needle happily goes above the half mark and after say 15-20 kms of driving if i push the car the needle starts to drop fast towards "E" somtimes even going below "E".
Now it gets scary since i do not know how much fuel is in the tank thus taking away the pleasure of driving.As i said before i had replaced the guage meter but same problem persist.Any ideas what the reason could be?
Thanks a bunch
Does it stay like that or does it return to normal level when you slow down again? If that is the case, it could be that the acceleration causes the fuel to move around / get accumulate towards the back of the tank and give out incorrect readings.
Maybe the float in the fuel tank is malfunctioning, something similar happened to me too the needle was stuck at quarter tank and i was thinking i am getting great mileage but when i went to fill up there was only a few ml of fuel left in the tank, got the float changed and its working fine.
Originally Posted by rageshgr
(Post 1422688)
Does it stay like that or does it return to normal level when you slow down again? If that is the case, it could be that the acceleration causes the fuel to move around / get accumulate towards the back of the tank and give out incorrect readings. |
Hi,rageshgr yes the guage comes to normal after some time say after i park the car and start again it seems fine.
Originally Posted by jav
(Post 1422785)
Maybe the float in the fuel tank is malfunctioning, something similar happened to me too the needle was stuck at quarter tank and i was thinking i am getting great mileage but when i went to fill up there was only a few ml of fuel left in the tank, got the float changed and its working fine. |
Hi jav, i was thinking of getting the float replaced too.How much did it cost you? Must be a messy job opening the fuel tank and all.
I got mine replaced under warranty but it was somewhere around 500, usually the float is on the top of the tank and is pretty easy to remove, it took just ten minutes to get it replaced
Originally Posted by sumeethaldankar
(Post 1422810)
Hi,rageshgr yes the guage comes to normal after some time say after i park the car and start again it seems fine. |
If it returns to normal only after some time , and not immediately, I too doubt a faulty float
(Post 1422683)
Hi guys,
My 12 yr old m800 (carb) fuel guage seems to fluctuate ie it moves sharply to "E" when i drive it the car hard say 4000-5000 rpm in second gear.Any ideas what the reason could be? |
I faced this problem on my old M800 as well. It was traced to a faulty float assemly and the entire assemby was replaced. I don't see whey you changed the guage initially when you faced this problem because, the guage is just an indicator, where as the real fault would lie on the component that is responsible for showing the right level of fuel in the tank namely the float assembly.
Change the float assembly and this problem will be solved. :)
Cheers,
gpa
Originally Posted by gpa
(Post 1423275)
I faced this problem on my old M800 as well. I don't see whey you changed the guage initially when you faced this problem because, the guage is just an indicator, where as the real fault would lie on the component that is responsible for showing the right level of fuel in the tank namely the float assembly. |
Hi gpa,
I had the guage changed as the temperauture guage was busted too.I guess i may have to go for a float change too.
thanks
Its the float in my opinion too. Cheers
