Old 9th September 2005, 18:48   #1
Deeps's Avatar
Thanked: 170 Times
What is the procedure for push-starting a car??
For me this has always been a "always wanted to know but too afraid to ask" kind of question. I haven't seen a car being push-started for years now and when i did see it i didn't have the technical knowledge that i do now (thanks to team-bhp). So, what is the correct method?
Deeps is offline
Old 9th September 2005, 19:21   #2
revtech's Avatar
Thanked: 39 Times
the normal method is you put it into first and keep the clutch pressed.get some one to push it and as it attains a decent speed leave the clutch.the jerk causes it to start.i definitly would want to read the technical way to do it as this is the most common and practical method by which its done
rev
revtech is offline
Old 9th September 2005, 20:05   #3
mclaren1885's Avatar
Thanked: 46 Times
Infractions: 0/1 (10)
i was thought to push the car in 2nd gear with the clutch pressed and not 1st gear..i could be wrong though..
mclaren1885 is offline
Old 9th September 2005, 20:11   #4
sridhar24's Avatar
Thanked: 90 Times
Normally even i prefer to do it in second gear if at all i have to push start the car.
sridhar24 is offline
Old 9th September 2005, 20:12   #5
drifter's Avatar
Thanked: 75 Times
its easier to push start in the 2nd gear...you would get less of a jerk from the engine...and overall less load on the components.
Drifter
drifter is offline
Old 9th September 2005, 20:14   #6
turbo_c's Avatar
Thanked: 13 Times
It's easier to push start my Esteem in 2nd... Maybe it depends on the car's gear ratios... In 1st, when I release the clutch, the car stops too quickly, while in 2nd, the engine gets to turn over a little bit before the car stops...
...also it reduces the chances of the poor souls pushing from behind suddenly smacking their noses on the back of the car!
In an MPFI car, you will need at least some minimum voltage in your battery (ie. battery should not be completely dead)... this is because the fuel lines to the injectors need to be pressurized and the ECU needs to be "awake" too... with a completely dead battery, an MPFI car just won't start.
- T u r b o C -
turbo_c is offline
Old 9th September 2005, 20:15   #7
viper's Avatar
Thanked: 20 Times
It is easier to start in second gear than first. reverse gear is also another option to consider if you happen to get stuck on a slope where it is difficult to push forward.
Viper
viper is offline
Old 9th September 2005, 20:24   #8
revtech's Avatar
Thanked: 39 Times
hey thanx next time i have to push start will try it in second.i have always done it in first and i remember in goa i had rented a yamaha rx135 the kick was borken and had to be jump started so i always did it in first.
Rev
revtech is offline
Old 9th September 2005, 20:29   #9
Thanked: 30 Times
I have heard that push starting is not recommended for MPFI cars..Apparently messes up the engine...not sure of the real reason though....
paharino1 is offline
Old 9th September 2005, 20:38   #10
drifter's Avatar
Thanked: 75 Times
Yeah i've heard that too...infact i remember my indica petrol manual said not to push start....but then it was push started 4-5 times...but didnt give any trouble.
Drifter
drifter is offline
Old 10th September 2005, 09:44   #11
GTO - Touring's Avatar
Thanked: 56 Times
It is not recommended to push start MPFi cars. Thats why I have a pair of jumper cables handy in the garage at all times.
GTO - Touring is offline
Old 10th September 2005, 12:33   #12
cnu
cnu's Avatar
Thanked: 121 Times
How are these useful ?
cnu is offline
Old 10th September 2005, 13:55   #13
Deeps's Avatar
Thanked: 170 Times
these cables can be used to to take power from the battery of another car to start your own.
Deeps is offline
Old 20th December 2014, 17:47   #14
humyum's Avatar
Thanked: 5,865 Times
Re: Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership
Originally Posted by sudev View Post
Do a push start. Slot in first. Clutch pressed. Ignition to on. Get two three people to push. Release clutch.
Once it starts go for a few kilometre spin. Should be okay.
Hey a push start is done in 'second' gear not first
humyum is offline
Old 20th December 2014, 17:50   #15
SS-Traveller's Avatar
Thanked: 28,735 Times
Is there any reason why push starting can't be done in first, third or even fourth or fifth gear?
SS-Traveller is offline
