Never noticed anything like this in any AT that I have driven and am puzzled.
When I stop the car and keep my foot on the brake pedal, like at a traffic signal, there is a bit of vibration in the car, and almost a feeling that it has not engaged neutral. Almost like the car is trying to move forwards and the brakes are holding it back.
If I shift to N or P the vibration disappears.
The manual also say that it will shift to N if left in D mode, your foot is on the brake, and there is not forward movement of the car.
Any suggestions?
seems like the car is trying to push itself ahead even in brakes pressed. I think some alignment on the box etc would do it fine, I have no idea on AT car, but from the things you have mentioned it seems something like half clutch (or even lesser clutch).
IMO, this is normal to ATs as the brakes ARE actually holding the car back if you are in D mode.
This is why recomended practice is to shift into N or P unless you are expecting to start off within the next few seconds. This is also partly the reason why AT cars tend to wear out their brakes faster.
Experts please?
I think the newer AT's automatically shift to N when they come to a halt in D.
This is a major step forward in the AT technology and a great brake pad and fuel saver. Please correct me if I am wrong...
If this does not work, get it fixed.
I think Anand is right. Modern ATs 'should' shift to N like I explained in the first post. Maybe I'll get it checked.
Was hoping for other Cruze owners to chip in with their experiences.
Off topic here Deepak.. What's the colour of your Cruze?
Modern automatics do not shift to "N" when you come to a stand still in "D", at least not in the current midsized cars what we have in India. When you release the brakes while in "D" the car will move forward. This is natural for all automatic vehicles.
Originally Posted by deepakvrao
(Post 1957132)
When I stop the car and keep my foot on the brake pedal, like at a traffic signal, there is a bit of vibration in the car, and almost a feeling that it has not engaged neutral. Almost like the car is trying to move forwards and the brakes are holding it back. |
I used to drive Civic, Mustang & Elantra AT's in US & I experience the same except for the vibration. So I tend to feel this is normal.
(Post 1957132)
If I shift to N or P the vibration disappears. The manual also say that it will shift to N if left in D mode, your foot is on the brake, and there is not forward movement of the car. |
I'm no expert in AT, however making a guess that it could be a clutch issue related to springs or something as there's a vibration also involved.
(Post 1957132)
Does varying pressure on brake pedal make any difference so that car electronics understand that car is standstill in D mode & it should shift to N mode.
Also check with other Cruze AT owner on forum, '
nadim_90210' is one of them.
OT: Doc, if your car doesn't behave this way, then it's likely that it has learned to do a 'bike track stand' so that it can start faster when traffic signal turns green.
I took a test drive of Cruze AT last week and drove for almost 30kms+ in peak traffic and open roads and felt the same way, when brakes are pressed there is a slight vibration and car is itching to move forward and minute you leave the brake pedal it surges forward.
I guess this seems to be normal in AT's as this was my second AT car that i have driven previous being a Santro.
(Post 1957132)
The manual also say that it will shift to N if left in D mode, your foot is on the brake, and there is not forward movement of the car. Any suggestions? |
Maybe the engine idling speed is high ? Just a hunch, considering that it is not shifting to N in this case, as per what your manual suggests.
Deepak,
Please get the auto transmission checked by your dealer.
Also I am not sure as to whether the auto should engage N when it is in D with your foot on the brake. That's not the case in the 6 speed DSG in the Jetta; neither is there any vibration.
in AT, when in D mode, the gear never goes to N on coming to a standstill. You have to hold the brakes to prevent the car from moving. Even cars like C-Class have to activate the Autohold function if you want to hold the car in D mode at standstill. This means that N is not engaged automatically.
Ideally the lever should be moved to N if you bring the car to a halt or else the brake pad life is being eaten into.
Originally Posted by Rudra Sen
(Post 1957282)
Off topic here Deepak.. What's the colour of your Cruze? |
Rudra,
Its White but not the more expensive Diamond White.
Originally Posted by jaguar.runs
(Post 1957360)
Modern automatics do not shift to "N" when you come to a stand still in "D", at least not in the current midsized cars what we have in India. When you release the brakes while in "D" the car will move forward. This is natural for all automatic vehicles. |
Thanks to all the guys who replied.
I rechecked the manual, and it says that it will go to idling rpm when in D and at a standstill. It did not say it would get into N. My mis read.
I have never felt this vibration in my Laura, or in any other AT that I have driven abroad so was wondering.
Mobike0008 also felt the same thing. I think I will check a TD car and see if thats the issue.
Maybe the idling is high? It shows about 800rpm though.
Meanwhile, I am learning to put it in N for longer stops.
Originally Posted by mobike008
(Post 1958223)
Exact description that I should have used.
