Closed Thread
Old 6th November 2005, 19:39   #1
lamborghini's Avatar
Thanked: 5,937 Times
Lancer Tire Rattling in the Trunk
Hey guys,
as many of you all know, we have a new lancer which is currently running on 14" godyear eagle Venturs - 195/60/R14.
Now the thing is that the spare tyre in the trunk is rattling quite a lot which is irritating. We have tried doing everything possible and have gotten it removed and put back and bolted from both the lancer dealerships, 2 different tyrewallas, everything.
The thing is that my jijaji and some other lancer owners who have the same and bigger tyres ( upto 16" ) aren't facing any problem.
To be more specific,
my jijaji who has a 2001/2002 lancer SFXi with the same size Venturas tyres isn't facing the problem.
Only difference is that his is the org. SFXi rims and we have the ones below.
Do You guys think the problem could be because of the rims?
thanks.
Side Profile -
lamborghini is offline
Old 6th November 2005, 20:03   #2
Thanked: 94 Times
Put something to cushion the noise in place and then secure the tyre to its designated area. Use a good foam/sponge type material.
bigman is offline
Old 6th November 2005, 20:23   #3
Thanks bro,
will try it tomorrow.
Old 7th November 2005, 05:12   #4
Sahil's Avatar
Thanked: 8,055 Times
The problem is because of your upsize. MY friend has the same problem for a while... he went back to Saifee in khar from whom he got his alloys and they gave him a larger bolt so that it would fit tight.
Sahil is offline
Old 7th November 2005, 06:54   #5
aseem's Avatar
Thanked: 443 Times
If the bolt of alloys is not tight, this could prove to be very very dangerous. Please change your alloys/bolt immidiately and do not jeopordize your and your families life. Here at TBHP safety comes before style of having alloys.
aseem is offline
Old 7th November 2005, 09:25   #6
devarshi84's Avatar
Thanked: 213 Times
OK maybe this will work out lamborghini.
try to put the spare tyre in your jijaji's trunk and try to put your jijaji's tyre in your trunk. see if any car makes noise.
If your car makes noise there is some problem in your car's spare tyre compartment
If your Jijaji's car makes noise then its the tyre that is the culprit.
devarshi84 is offline
Old 7th November 2005, 16:03   #7
revtech's Avatar
Thanked: 39 Times
i agree.try that out and see what happens
no seriously just try and put some foam or cloth or something to eleminate the noise.it should do the job.
Rev
revtech is offline
Old 7th November 2005, 18:36   #8
autopsyche's Avatar
Thanked: 36 Times
errrr, wouldnt you rather read the post first before replying?
autopsyche is offline
Old 7th November 2005, 19:23   #9
raajks's Avatar
Thanked: 119 Times
If your Jijaji's car makes noise then its the tyre that is the culprit."
I guess if you try Dev's suggestion. You should be able to crack it
raajks is offline
Old 7th November 2005, 21:01   #10
If i try Dev's suggestion, i would have to travel to baroda/Vadodara.
Anyway,
I think it could be the bolts as the culprit,
I have gotten the bolts on the tyres changed, just not the bolts in the trunk and the reason for the upsize was infact safety and better handling.
Will go and get the bolts changed tomorrow.
Old 7th November 2005, 21:05   #11
karthik247's Avatar
Thanked: 30 Times
Since the tyre is placed upside down, it culd be the spokes touchin the bottom cuz in some alloys the spokes are kinda buldge a lil.....well its just a thought
karthik247 is offline
Old 8th November 2005, 01:56   #12
devarshi84's Avatar
Thanked: 213 Times
Anyway,
Not really. Try any lancer in fact for the tyre swap. If the tyre is making noise in any other lancer than its the tyre that is the culprit.
until then try to put the other lancers standard tyre in your car.
you will know where the problem lies. the dealer will let you do this for your help.
Old 8th November 2005, 14:57   #13
Thanked: 77 Times
This could be dumbest reply on this thread, but how about padding with thermacole below the tyre till you find good solution to your problem?
RX135 is offline
Old 15th November 2005, 04:51   #14
devarshi84's Avatar
Thanked: 213 Times
So lamborghini what is the outcome? Did you get your problem fixed?
did you try with the dealer?
Old 17th November 2005, 22:20   #15
Well,
i tried the foam suggestion and the noise has almost dissapeared.
Still conducting further research on it.
Closed Thread
