Re: Stop at nothing. Not even gears. The 1st A-Star AT ownership on Team-BHP Hello SupremeBaleno, it is good to see you are close to solving the issue. Since a single front wheel sensor fixed the Speedometer and Odometer issue, it seems that in Astar AT vehicle speed is determined by a single ABS sensor only. This is surprising to me, since I was expecting that the average of 2 front wheel sensor inputs would determine the correct speed of the car ! After all different wheels rotate at different speeds during various instances of the drive; that's the reason cars have 4 ABS sensors anyway.
I too suspected the lethargic function of the speedometer after it started working, looks like i did not imagine it after all !
Replacing of the Right Front Wheel ABS sensor should switch of the ABS warning light, just like it happened in my case. Please try that before touching the rear wheel sensors.
I wonder why your ABS issue was not diagnosed earlier, in my case OBD2 scanner available in MASS straightaway showed the 2 relevant error codes indicating the front 2 ABS sensors have failed. Also in live data mode, the OBD2 scanner picked up 0 speed values from both the front wheels during test drive.
Regarding GSD, truly nobody in Maruti India seems to know its exact functionality; I have enquired enough. Based on my research I believe that the AT gearbox makes shift decisions (via ECU) by comparing gearbox output shaft RPM (captured by GSD) rather than actual wheel RPM (captured by ABS sensors) to current engine RPM (captured by Sensor, Speed Input). That is why the GSD is mechanical rather than magnetic, as this would ensure more accuracy.
Do keep us posted. |
