Closed Thread
Thread Tools
Old 3rd March 2006, 17:28   #1 (permalink)
low_bass_makker's Avatar
Default Help ... Need High Output Alternator TOO MUCH LOAD
Hi I joined today only I liked the site very much, good stuff and very informatative. But here in India we get the audio stuff but very difficulty . ok let us leave everything aside .
I bought two alpine MRD-M1005 amps each is capable of making 1000 watts rms in 2 ohms so now must estimate how much power they will need to run i have installed optima yellow top also but the car alternater is to small to handle this load it is only 70 Amps to small for all the stuff. So i need some advice for the HIGH OUTPUT ALTERNATER.
low_bass_makker is offline
Old 3rd March 2006, 17:40   #2 (permalink)
navin's Avatar
Bosch makes them to 200A. THey mgiht be available from Mico Bosch
Q. I have installed a mega-watt sound system or have other electricity demanding components in my car. Does Bosch have an alternator that can power all these systems?
A. For applications that demand high power, such as cars outfitted with mega-watt sound systems, Bosch offers High-Output Alternators that are 100% new and are engineered to produce maximum amperage at lower rpms. This allows the charging system to keep up with the amplifiers and eliminates battery rundown. These units can create up to 200 amps, which is nearly double the output of some stock units they replace. These alternators have been designed from the beginning to generate high output and have features such as additional copper wire windings in the stator, ceramic coated housings to handle high heat, Nomex® insulation (the same kind used in flame resistant clothing), soldered connections coated with silicone to reduce corrosion and protect against heat and vibration, and smaller diameter T6160 aircraft grade aluminum pulleys which reduce weight and allow the unit to spin faster at low rpm. Best of all, these units fit the same as the original and are designed as bolt-in direct replacements.
navin is offline
Old 3rd March 2006, 17:49   #3 (permalink)
Thanks for such apromt reply. But from where do i get them i have searched in my area Lucas TVS makes 135 amps alternater for TATA Safari but i do not know that its alternater will fit in my car. Mine is Swift here is a link where u see a bit of it. http://www.sounddomain.com/ride/2277199
Old 3rd March 2006, 18:09   #4 (permalink)
Autophile's Avatar
Low Bass,
What car do you have. What size power cables are you using. Fitting 200A alternator to 75aH battery will not be a great help.
We have run 4 amplifers with total rating of 200 Amps on Optima battery without any dimming problems on a standard alternator.
Please tell us what other equipment are you using.
__________________
Danes Don't Lie !
Autophile is offline
Old 3rd March 2006, 18:14   #5 (permalink)
Sir I am using AWG 2 wiring kit rest u can see on this page http://www.sounddomain.com/ride/2277199
Old 3rd March 2006, 18:15   #6 (permalink)
Autophile's Avatar
I have seen the equipment on the soundomain site. Check the final impedance (load) on the alpine amplifier.
The culprit in your power circuit are the Boss Caps. Just remove them from the circuit and see the difference also using better cables will help.
The equipment you are using is not a very big load on swifts electrical system. And you have already upgraded the battery.
__________________
Danes Don't Lie !
Old 3rd March 2006, 18:23   #7 (permalink)
Autophile's Avatar
There are lot of issues with the installation which I see in the pictures.
Call Manik (Driven) @ 9811775777. He will help you with this.
__________________
Danes Don't Lie !
Old 3rd March 2006, 18:24   #8 (permalink)
Final load is 2 ohms on each amp they are stable at 2 ohms also. If i remove the caps no diff is seen but voltage drops more i.e 11.5 volts min at high volume but if i lower the volume the voltage comes back to 14.6 volts I am using Industrisal grade heavy duty wires must more superior that what we get in market as amp car kits .The total load is of 3 amps 2 of them are alpine for subs and 1 pioneer for speakers total of which amps would get to nearly 190A which i think is bigger for a 70A alternater and a 41AHh battery.
If u dont mind Sir what amps u r using and which car do u have any pic would be great
Old 3rd March 2006, 18:38   #9 (permalink)
Autophile's Avatar
The powercables you are using are thin strands one or thick strands. Maybe your cables are not meant for DC and the voltage drops. Thats why the amplifiers are not getting the proper operating voltage.
We have installed the most exotic and expensive equipment that you can think of. Check out threads by me and gunbir.
One of them is :
http://www.team-bhp.com/forum/car-en...ll-pics-3.html ("IMAGE" Autopsyche Lancer ICE Install Pics)
__________________
Danes Don't Lie !
Old 3rd March 2006, 19:50   #10 (permalink)
jkdas's Avatar
HERE IS HIS INSTALL
1) HEAD UNIT -> PIONEER DEH-P9400MP
PLEASE CHECK THE LINK FOR INFO
2) AMP FOR MIDS AND HIGHS -> PIONEER GMX-944
WORKING AT 75 X 4 WATTS RMS AT 4 OHMS
3) SPEAKERS AND TWEETERS -> PIONEER TS-C160R KEVLAR SET
TWO PAIRS ONE IN FRONT AND ONE IN BACK
CHECK CHECK THE LINK FOR INFO
4) AMP FOR BASS ->ALPINE MRD-M1005
WORKING AT 1000 WATTS RMS AT 2 OHMS
USE CHECK THE LINK FOR INFO
5) WOOFER -> PIONEER TS-W3004SPL
6) CUSTOM BOX VOULME -> 1.1 CUBIC FEET WITH 3 INCH DIA AND 8 INCH DEPTH PORT
7) 2 AWG WIRING FOR AMPS AND BOSS RCA
8) 2 ONE FARAD BOSS CAPACITOR
phew,whers the boot? and that wiring is what you call wiring.
xenon looks cool
__________________
-__-
jkdas is offline
Old 4th March 2006, 10:48   #11 (permalink)
Thanks every one for ur advice it was very much help full in improving my system but atleast someone tell me if they know from where do i get a good high output alternater
Old 4th March 2006, 23:39   #12 (permalink)
any repiles will be helpful if anyone can
Old 5th March 2006, 05:06   #13 (permalink)
Try looking for it in mayapuri. ive heard u can get loads of things from there for cars.
No idea about the shop. And it's near Janakpuri.
abhishek2 is offline
Old 5th March 2006, 23:26   #14 (permalink)
navin's Avatar
A big alternator will over charge a small battery and reduce battery life.
A 944 and a MRD1000 should be ok with a 75amp battery.
I suspect the Pio woofer will not be able to asorb 1000W without hitting it's Xmax even in a 1cu ft. sealed box in a ported box it will hit Xmax even earlier. so in effect either you are getting a lot of bass distortion or your Alpine amps is being underutillised. besides the MRD puts 1000W in 2 ohms but if each amp is only driving one sub then it is going to be be limited at 500W / 4 ohms (about 11A continous each).
I'd change the Boss wiring. remove the Boss caps (as suggested by JB) and check.
lastly if you got 15,000 songs in a 30GB ipod your compression ratio is definitely not good enough. I'd suggest looking at EAC and LAME and hydrogenaudio.org for more info on how to rip good quality MP3s.
navin is offline
Old 6th March 2006, 11:58   #15 (permalink)
Thanks sir. If u have seen the pioneer sub site on the net it is a dvc sub not svc so it is wired a 2 ohms for each alpine and it is giving 1000 watts to each sub and sub can handle that type of power beacuse it is 1000 nominal and 3000 watts max. So i think the sub is ok with the amp. Also the ported box volume is ok with the size given by the pioneer so it is perefctly tuned as per requirement. and is sounding very good. Rest i am going to change the whole wiring with audison stuff soon
lastly i am putting my songs on my ipod at 256-320 kps bitrate which is more than cd quality also my ipod is half full so i not getting in 15000 songs but quality of songs.
also check this link also
http://forum.sounddomain.com/ubb/ult...c;f=3;t=030889
Closed Thread
Thread Tools
AC Issues. High Engine Load Gangsta Technical Stuff 27 13th August 2008 17:44
How is Dzire with full load ? pawan_pullarwar The Indian Car Scene!! 10 3rd April 2008 11:04
Maximum Load / Weight Vinay DL Technical Stuff 2 23rd November 2007 09:42
Load Carriers? Harrie Luxury, Imports & Niche 2 5th June 2006 02:57
Need Higher Output Alternator And Electrical Help Tool Modifications & Accessories 5 1st June 2006 19:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
