| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: May 2007 Location: Chennai
| I got my NHC Type 1 ICE at Sound Factor in Bangalore on Saturday. This is the system that I got: Front: Infinity Reference 6020CS Rear: Infinity Reference 6022i Sub: JBL CS1204B Amp: JBL GTO4060 Wiring Kit : Preetham recommended scosche kit for Rs. 2500 and I am using that. Now the problem is that there is a continuous clicking noise in the front tweeter. At least that's all I thought the problem was :-(. At first, we thought the tweeter was a problem, so we replaced it. Still no luck. Then we changed the crossover, no luck again. Then the guy from Preetham's team said that my Head Unit (Dual, not known for its reliability) could be the problem. So I asked him to check with my old Pioneer. Still the same noise. Then we thought the problem was with the wiring. I asked him to check the wiring. I don't know what is the correct way to check the wiring, but he said he checked them and there was still the noise. Moreover, the noise came even when the volume was at 0 (as long as the head unit was on) and only on the front preout. We connected the subwoofer on the front preout and the subwoofer also emitted those noises. The noise was not there when the sub was connected correctly. The rears were not making any noise (but they were not connected through the amp). When the front speakers were connected to the rears still the noise persisted. Then we thought the problem could be with the amp, so he brings an Infinity 47a and still the same noise. By now all of them are convinced that the head unit is the culprit. But I am not, because the probability of two head units having exactly the same problem is kinda low. So in the end he brings a Pioneer 7950 and now the noise is not there. I figure its my bad luck and since both the head units seem to have a problem, I put the new one back and drive back to Chennai. But somehow I am not satisfied with that explanation (I know, I am pig headed). But today I found some more issues. While playing FM, there is noticeable static. Moreover, when I accelerate or when the rpm rises, there is a corresponding increase in the whine. Again this is when the volume is at 0. There is also some interruption when I honk. This is what resurfaces my doubts about my head unit not being the problem. Because, I have heard this same sort of thing in some other cars as well. I apologise for the looong post, but does somebody have any suggestions for this? Is there any "bang my head on the keyboard" sort of obvious solutions that I have missed or is it my head unit after all? |
| | #2 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
2. your wiring need tobe checked. are the power wires running along side the RCA wires? What wires are you using?
__________________ Scixelsyd Etinu | |
| | #3 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | from my experience, it is either wiring or the HU. nothing else....Had seen exactly same problems using DUAL HU, but am surprised how Pio has that....may be you would also like to check the main current (battery) wire for any cuts etc.
__________________ SINGH IS KINNNNNNNG.. |
| | #5 (permalink) |
| BHPian Join Date: Aug 2007 Location: Noida
| Check the RCA cables. I had the same problem in my car and on changing the RCA cable for the front speakers the problem disappeared There is also a drity fix for it. Attach a wire to the outer connector of the rca cable which is carrying the signal for the speakers that are whining. Ground this wire either at the HU end or the amplifier end. Works wonders. Also, ensure that you are running your rca and power cables seperately |
| | #6 (permalink) | ||||
| Quote:
2. 16 gauge BOSS cables for the speakers (10 guage monster for the sub, 8G scosche for power and Scosche RCA cables). I searched the forum and you have said earlier that Boss cables are notorious for their inability to shield properly. Are the correct rating wires used? I was very surprised to see the scosche RCA cables, they were very very thin. The monster RCA interconnects that I use at home are thrice as thick. Are the car audio cables thinner so that they can bend easily? Do they shield equally well considering there is a lot of electronics in the car. Quote:
I tried that as soon as I came back from the office. It was at 50%, the noise is still present at 25%. At around 10% it starts reducing a bit. Quote:
Thanks guys. The consensus from the gurus and Gandalf (sorry navin, that's the mental picture I have of you :-) ) seems to be defective wiring. The power and the RCA cables are I'll have to check it this saturday. | ||||
| | #9 (permalink) | |
| Senior - BHPian | Quote:
__________________ ... Everything should be made as simple as possible, but not simpler Last edited by rocksterraghu : 11th September 2007 at 23:37. | |
| | #11 (permalink) |
| And on a totally unrelated note, how is a sub generally fastened down? The reason I ask is that I can hear the sub move around whenever I brake. Is that normal? The sub is fairly heavy, so not sure why it keeps moving around like that. |
| | #13 (permalink) | |
| Quote:
| | #15 (permalink) |
| This weekend I could not get much work done as it was Vinayak Chaturthi and everyone was on a break. But I did what I could to check out the root cause of the problem. 1. Alternator whine: I tried grounding the RCA wires on the amp side. Very slight reduction in the whine. So I guess that grounding is the problem. 2. Clicking noise: It seems to be more and more likely that my HU is the cause. As I mentioned in another thread I connected my iPod directly to the amp using a 3.5mm to RCA cable and there were no clicks and the sound quality was very good. But again, while doing this I noticed that the RCA cable has been split and then stuck together using a tape. Probably I dont want to change the HU, but I have a feeling that the RCA could be the culprit here :-). I am just updating the status so that if someone notices something then they could tell me. One more symptom that I found. When the engine is off and I listen to the HU, at 0 there is no clicking noise. I get it only when I change the volume to 1 (and it does not increase with the volume). However, when I start the engine, I get the noise even when the volume is at 0. If its not RCA, I really will have to look for a good HU with proper iPod support or skip the HU and come up with a different solution. |
| Thread Tools | |
Similar Threads | ||||
| The Bonnet Pops Open!! | ph03n!x | Street Experiences | 5 | 21st July 2008 19:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
How I wish it was!!
