[PREFACE: With my current set of projects coming to an end this week, I am going to finally find time to work on Project Nomad: to convert my Gypsy into an all-terrain mini-motor home. This is the first of the series of threads on this topic.]
I have fitted a secondary battery for power inside the Gypsy when in camping mode, so i dont discharge my main battery. I went for a 55AH Amaron sealed acid battery. A bigger deep cycle type battery would have been nice, but I wanted to avoid mounting the battery in the cabin to save space and the 55A battery was the largest that fit under the bonnet on the left side.
Right now the secondary battery is being charged OFF the primary battery with a manual cut-off switch inside the car. The switch disconnects the batteries to prevent the main battery from being discharged when in overnight use.
Primary Battery connections:
- Amplifier 2ch
- Carputer
- LCD-7"
- Fog Lights Hella 3000
- Cig Lighter Socket
Secondary Battery connections:
- 2x 90cfm Vent Fans with control switch. these run through the night when camping. rated consumption is 9A for 8 hours.
- 2x DC power outlets - 1L & 1R for laptops. Typically only one is used at a time.
- Rear cabin lights
In a typical use situation, I am driving 400+ kms followed by 2/3 days in which average driving is 50/60 kms or less. At night the secondary battery is in use for most of the time. With this kind of use the secondary battery gets discharged typically by day 3 since it is not being driven sufficiently to get fully charged. The battery also gets completely discharged in about 6 hours of laptop use.
To overcome this situation, I am now
considering installing solar panels to charge the second battery. After evaluating options, i have chosen 37W mono-crystalline panels with the foll specs:
# Maximum Power (Pmax) - 37W
# Max. Power Voltage (Vmax) - 16.4V
# Max. Power Current (Imax) - 2.25A
# Open Circuit Voltage (Voc) - 21.0V
# Short Current Current (Isc) - 2.50A
# Dimensions (mm) - 966X430X34
# Weight - 5Kg
With 8 hours of sunlight, it should be possible to replenish lost charge everyday. The panel will be mounted on rails on the rear roof of the gypsy to enable easy mounting/dismounting to enable easy storage when not on touring duty.
Another idea in consideration, courtesy an electronics geek from this forum
, is to fit in a zener diode borrowed from a UPS between the primary and secondary batteries to eliminate the manual cutoff switch.
All suggestions welcome!
