| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| Hey guys... tell me something. My friend's TCIC Indica's Intercooler looked to have a peculiar problem yesterday night when we raised the hood. It has those fine honeycomb like mesh/fin. Now many of these fins seemed to have collapsed... almost like someone pressed them with something heavy. The light aluminium fins (they look aluminium to me) seemed to have crumpled at many places. Today when he took it to SS they said that it has happened because of the heat and is not a problem. Apparently they change the intercooler after 40000 kms. However this car has just run some 7500 kms. Now, does that sound very credible? I mean I do not know whether those honeycomb like structures actually collapse like that because of heat. And in the process the pores are also getting closed. Won't that cause problems in the near future? |
| | #2 (permalink) |
| Senior - BHPian | I doubt they collapse due to heat. If that is the case then all radiators and A/C condenser fins will collapse too. I feel it is a definate case or repair. Try and find some sealed pipes (copper welded) inbetween the crumpled fins. And an intercooler replacement at 40k sounds new to me.
__________________ /F/I/A/T/ |
| | #3 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| You can have a normal AC guy reshape the fins with a Copper Brush they have..! However I suspect Sabotage, Technically possible with Heat in the Bay-But even then Unlikely..!
__________________ " When was the last time, You did something for the first time " |
| | #4 (permalink) |
| moralfibre... buddy these are very delicate looking things made out of so light a material that they look like you can make them collapse by just pushing hard on them with bare hands. I think very light weight aluminium sort of thing. That is why I could not completely negate the theory. Also the SS guy did not look like thinking over it... as if this is very regular. So I was wondering whether it could be true. Wolfi... I felt the pores should be opened for effective working of the Intercooler. I actually put the keys into the fins and straightened a few. It is so light that seems to happen very easily. Is it really necessary to visit a AC mech for this prob? I mean a copper brush... what if I do it myself with something like a key? There does not seem to be anything delicate at the reachable depths of these pores that may get damaged. |
| | #5 (permalink) |
| those AC guys can give a Even reshape, gap between each fin and all..Else you can try with key or even hands, just be careful you don't nick yourself
| | #7 (permalink) |
| Hmmm... Looks like no one has encountered this problem at least on our board. Considering the number of Indigos and Indica TCICs on the road looks like a unique problem to me. Lets see. Maybe I will also post a pic later at night to give you guys an idea of this wierd problem. |
| | #8 (permalink) |
| BHPian Join Date: Mar 2007 Location: Delhi
| Hello zappo, please post a picture of collapsed fins, it is highly unlikely to be collapsed by heat of engine bay, as they are designed to work inside engine bay. Secondly engine bay is hot but not hot enough to cause a plastic deformation due to heat alone, that too under absence of external force, its impossible by underhood heat to get deformation by weight of material itself. most likely caused by mishandling of some tool by technician. anyway please do post the picture
__________________ Arun |
| | #9 (permalink) |
| Exactly my thoughts Arun. That is why I was very surprised when this logic came through! I thought they looked like some mech has caused the injury to the Intercooler due to his sheer callousness when the car went for the first service. The fins are actually more like fan fold of very thin aluminium sheet (much like if you fan fold a thin strip of paper). There are row after row of these. Generally giving it a look of a fine mesh/grill etc. I will try to post a pic tonight from home. |
| | #10 (permalink) |
| yes zappo i know structure of intercooler very well, just asked for picture as it can clear the tell tales of injury, intercooler in indica is place in very awkward position(inclined near tappet cover), an easy slip of spanner may bang the fins to be folded. no need for change, as some fellows explained that they can be repaired. Just ensure that there is enough way between the fins for air to ventilate through, after repairs.If you suspect a deed of mechanic, ask TASS ppl to repair it free of cost. its another funny story/excuse from TASS people, they are good for nothing. ![]()
| | #11 (permalink) | |
| Senior - BHPian | The fin mesh is so thin that a slight pressure will bend them and especially if the bay is hot then all the more easier. A weird thought has come to my mind. Sometimes i've seen mechanics climb onto the engine to access certain parts at the back end near clutch housing etc. Maybe the body weight has damaged the fins. While no one at TASC will accept this, you may have to shout over the din there to be heard.. ![]() BTW, a good AC guy will have a device - generally a steel comb with which he can straighten them all. It is a painstaking job. The back mesh/grill of my window AC had a such a problem over the years. The heat dissipation was becoming a problem. My AC guy straightened those fins with that metal comb and took around 2 hours to do the job properly.. Quote:
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx | |
| | #12 (permalink) |
| Hmmm... here's a pic of what has happened. I am sure it has happened during 1st service, only that we spotted it late :P On second thoughts... look at the way it has happened. If it would have happened by accident then it would have been a localized damage. However it has happened all over the place in a random manner. Moreover in the second row some fins are not exactly collapsed but just look a bit squeezed. Could it be that the mech had a point? Can it happen due to the intense heat that is sweeping across hyderabad nowadays! ![]()
__________________ Announcements are important. Last edited by Zappo : 25th May 2007 at 03:14. |
| | #14 (permalink) |
| Senior - BHPian Join Date: May 2006 Location: Chennai
| More than worry about the shape of the fins..which Definitely looks man made..look out for an internal block in the intercooler..This will have a negative effect on your Turbo as well as engine..
__________________ Storm ing the Roads!!! |
| | #15 (permalink) |
| If they are offering a Free replacement due to heat damage, get a new one..Will be better..! Else like most of us suggested..Find a AC mech and get it done at earliest
| Thread Tools | |
Similar Threads | ||||
| Indica Diesel Turbo with/without the intercooler? | vishmath | Technical Stuff | 1 | 27th September 2007 18:41 |
| Indica TCIC vs. Indica DICOR | hell_rider | The Indian Car Scene | 11 | 13th March 2007 22:22 |
| Indica TCIC - updated - 6500km after 1st service | hell_rider | Long-Term Ownership Reviews | 49 | 2nd June 2006 14:33 |
| indica tcic under test | milin | The Indian Car Scene | 17 | 3rd October 2005 13:38 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
