Thread Tools
Old 3rd July 2007, 22:53   #1 (permalink)
Exclamation Swift : Making metal rubbing sound : Help
From friday I have hearing some sort of metallic sound when ever my car goes over the raod hump. The Mondavi at Vijayanagar, after a test drive informed me that, it was because of PS machanisam in the driver road and lubricated the PS levers.
However, I am still hearing the same, as we had to go to Mysore on saturday I couldn't take the car back to service station.
Would request your help to address this issue. Here are some pointers to assist you
1. Sound is heard when the front wheel goes over the hump (both while climbing and also getting down or bad un even road surface), even at very low speed.
2. Sound is sort of what you can get, when a metallic rod taps a empty metallic cylinder
3. When the car is stationary and the front suspension is pushed and released, no sound is heared, so it may not be suspension.
regards,
-manju
manjubp is offline   Reply With Quote
Old 6th July 2007, 14:29   #2 (permalink)
Sowmya's Avatar
Have the dealer (or an independent mechanic) check the hub bearings - particularly the front ones
Sowmya is offline   Reply With Quote
Old 6th July 2007, 15:43   #3 (permalink)
WhiteKnight's Avatar
Check the lower arm. Worn out lower arm bush could cause this. But is it a new car?
__________________
"When the going gets TOUGH.....Great ones PARTY"
WhiteKnight is offline   Reply With Quote
Old 6th July 2007, 16:14   #4 (permalink)
Shan2nu's Avatar
I doubt this has anything to do with the suspension. I think what you're hearing is the engine knocking. Happens if you try accelerating from very low rpms as the engine isn't producing enuf torque to overcome the load.
PS : But do get the suspension checked (just in case).
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 9th July 2007, 11:17   #5 (permalink)
Today I have left the car for 10K KMs service and I have reported them the issue. Hopefully they will check the same.
Yes, it is around 7 months old with 9857KMs
Shan2nu
Yes, I do had this doubt, however I was hearing even when the car was in first gear, especially even when it is gradient, where car can just role over.
Thanks to every one, hopefully the Mandovi at Willson Gardon will address this issue, along with fixing a running board scratch, which I had it yesterday. They have quoted Rs.3500/- for the same.
regards,
-manju
Old 13th July 2007, 06:15   #6 (permalink)
Got the car back from service, at first they have not even attend the problem. Then I took the car back to them and had to point out them that this has been not addressed. After a day at service station, yesterday I got the car back. They have lubricated struds, which were causing this noise. Now at this time it looks all fine.
regards,
-manju
Old 13th July 2007, 11:17   #7 (permalink)
Default Metallic sounds on slopes
hi all... I have a 3 month old Swift VXi and it makes these strange metallic sounds while I'm climbing down a steep incline and specially when it is raining. I had earlier heard similar sounds from my 10 year old Premier 118ne. It seems like the brakes aren't holding but the calipers are scraping against the metal. The sounds started after the recent Mumbai's heavy rains.
You're in Vijaynagar, lots of steep slopes down there, try to slow down your car when it is pouring and let me know.
Thanks in advance.
adrena is offline   Reply With Quote
Old 13th July 2007, 19:17   #8 (permalink)
Ricky_63's Avatar
Bearings will not emit the kind of sound that has been explained - it has to be the strut spring in all probability.
__________________
Everybody is entitled...... to an opinion !!
Old 14th July 2007, 13:02   #9 (permalink)
Thanks in advance.
Adrena, the problem was noticed every where, not necessarily only vijayanagar.
regards,
-manju
Thread Tools
A little hum and slight metal grind kind of sound sreenivass Technical Stuff 11 17th May 2008 20:05
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 17:31
Matiz making sound as though a K&n filter is present rahul_intlad Modifications & Accessories 21 14th August 2007 12:33
..car making booming kinda sound.. ns_jughead Technical Stuff 2 26th June 2006 02:58
Swift--Body Metal Thickness ivor Technical Stuff 15 6th May 2006 00:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
