Thread Tools
Old 4th January 2008, 10:38   #1 (permalink)
androdev's Avatar
Default Help! Corsa 1.4 engine temp rise
My 27K corsa 1.4 engine temperature rises close to red mark.
I found that cooling fan switches on its own after driving for some distance and the temp starts rising. so i switch on AC, and the cooling fan starts and them engine temp goes back to normal.
Anybody got any clue?
androdev is offline   Reply With Quote
Old 4th January 2008, 11:03   #2 (permalink)
adman77's Avatar
The Corsa has a tendency to heat up. But its quite normal. Even I got worried when I got my new car but the GM guys said there's nothing to worry about. It'll go close to the red mark but it won't touch the red mark. Just keep checking yout coolant level. Don't worry.
OT: I might need some help from you and your car in Bangalore.
__________________
I don't know where I'm going, but I want to get there fast.
adman77 is offline   Reply With Quote
Old 4th January 2008, 11:10   #3 (permalink)
androdev's Avatar
Sure. you can PM me. It's my wife's car, btw.
Old 4th January 2008, 11:21   #4 (permalink)
gkrishn's Avatar
Are you noticing this for first time after about 27k km? Then get it checked. But the sundaram has become useless nowadays. You will need to book an appointment like some 20 days before.
Only twice i saw the temp needle go beyond 1/2 way mark. Once it was when I redlined at first gear. After a while it cooled down to normal temp. The second time it went close to red line for no obvious reason. Then found there was no coolant left in the container, which was because of a leaky hose.
This is how i define normal temp gauge position for corsa. On highway cruising it stays at 1/4th mark. In peak traffic, it stays just below 1/2 way mark.
I don't think temp hitting red is normal. Check it out as soon as possible.
This job is not yet done?!?!?
__________________
In the Indian system of education, it is only a technique of cramming, retrieving and reproducing.
gkrishn is offline   Reply With Quote
Old 4th January 2008, 11:36   #5 (permalink)
adman77's Avatar
Originally Posted by gkrishn View Post
This is how i define normal temp gauge position for corsa. On highway cruising it stays at 1/4th mark. In peak traffic, it stays just below 1/2 way mark. I don't think temp hitting red is normal. Check it out as soon as possible.
Well, my temp usually stays just above the halfway mark and ocassionaly goes beyond, but never touches the red mark. I even reffered to the owners manual which states that this is normal as the temp gauge gives readings from the coolant chamber and it happens because the coolant chamber is pressurized.
That job was never done. This is for another job now.
__________________
Old 4th January 2008, 12:04   #6 (permalink)
Team-BHP Moderator
Jaggu's Avatar
dont know corsa specific but check if the temp guage hits red, my iKON had this funny problem and this was diagnosed to a faulty temp sensor.
Did you mean to say the Radiator fan comes on its own? OR it comes ON after you switch ON AC?
If latter please check Fuses.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Thread Tools
May your stocks rise... Dillusionalist Introduce yourself 10 29th May 2007 07:43
Small plane crashes into N.Y. high-rise abhibh Shifting gears 4 12th October 2006 10:43
At what Temp should the Engine Oil be drained off ? mithun Technical Stuff 3 14th August 2006 16:18
OHC Temp Rises to Max! buzzin_hornets Technical Stuff 25 25th February 2006 20:19
Quality of Indian cars on the rise shuvc The Indian Car Scene!! 9 14th December 2005 12:42
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
