1-1.2k RPM while idling, A.S.S says to change injector CRDi done 40k Accent VIVA There seems to be a problem with the Accent VIVA CRDi, the problem is that even in idling the RPM needle reaches around 1.2K earlier it used to hover below 1k i dont know the reason for this but it is causing problems in acceleration and maintaining speed.
I recently had the clutch plate changed and the car worked fine. I took the car to the Hyundai A.S.S. in Solan they told me that one of the three injectors is not working properly and has to be changed
They told me it would cost around 70k to change the injector how can this be the fault of a injector, can anyone please tell me if they are trying to get some money out of me without reason since the car has just done 40k and was bought in 2005.
SYMPTOMS
The acceleration dies without any reason one second it works fine and then suddenly the acceleration dies and speed decreases all this while my foot is on the accelerator, the acceleration again goes back to normal after a few seconds.
It almost seems that the accelerator is not pressed at all, i have tried to pump the accelerator when this happened but it did not work whatever i tried to do.
A.S.S. POV
Car has done 40k one of its injector has to be replaced and the injector cant be fixed. The price for the single injector is about Rs.70,000 and it will take 4 days to fix.
MY POV
I have already gotten the clutch plate and the battery changed i cant take a hit of Rs.70,000 more without more conclusive proof. The A.S.S. engg. could not explain exactly what was wrong with the injector, i am wondering if its a problem with a injectors it could be a idling valve or something else.
CONCLUSION
If the problem is really injector related then its a big problem because that would mean i will have to spend 70k on my old car that i wanted to use as a secondary when i buy a new one after a few months "Waiting for Linea 1.6".
The best thing to do in that case would be to sell the car and get a new one which i really dont want to do, so what do you people think can it be injector related problem?
Reason: Changing the title since A.S.S comes up as *** in there are no dots in between
