ENGINE,GEARBOX and PERFORMANCE:
Maruti has consciously worked on the drivability aspect and the power delivery is now bit more linear. The turbo now comes to business at around 17-800 instead of 20-2100 rpm as was incase of previous dzire. But the engine still feels almost dead below 1400 rpm and it doesn’t pull as cleanly as incase of Ford’s TDCi or Logan’s DCi. At the end of the day it is among the smallest 4 cylinder diesel engine around and it behaves that way.
Engine is a different beast once it is in the turbo zone. Keep the revs above 2000 rpm and you will be rewarded with some strong torque delivery. While the drive in the traffic has improved, DDiS is a strong highway performer as it always was. Its infact easy to keep up with bigger petrol engines if you are in power band. Healthier Power: weight ratio benefits the car and I am sure new dzire will be quicker than the older model in terms of outright acceleration.
Fiat seems to have developed the Multijet engine keeping Swift in mind. It fits the bay so well
At 23.4 Kmpl ARAI rating, new dzire is the most fuel efficient car among all Multijet applications. The reason being revised (shorter) first two gear ratios and slightly milder state of tune. Yes, the engine doesn’t feel as free revving (for a diesel) as it was in the BS3 DDiS models. Anything over 3500rpm and the engine feels bit coarse , so its best to shift earlier and make use of available torque. Clearly fuel efficiency and stricter emission norms are given more priority here.
Refinement (NVH) levels are impressive for a budget level sedan. Cabin is relatively free from engine obtrusions and its only when you rev the engine, some diesel clatter does intrude but that’s more to do with average level of cabin insulation. At the back seat one will be hard pressed to know if it is a diesel when driven sedately. DDiS (Infact the pedigree itself) is still among the more refined engines money can buy in this price range. Yet, the i20’s free revving CRDi engine remains the smoothest in its category.
Gearshift has been a traditional Maruti strength and dzire is no different. It has got a slick shifting short throw gearbox with well defined slots. It does require some effort for the shift action though. Short travel clutch compliments the gearbox well. Handbrake lever though feels to be of average quality for a 8 lakh rupees car
SUSPENSION,DYNAMICS and BRAKING:
Based on the all new swift’s suspension new dzire is a good step ahead of the previous car. The suspension is now more refined, matured and comfortable. This is definitely true when you drive car through potholed roads and you find it is quite composed without crashing. Average and low speed ride is on the comfier side and it will pamper the passengers well. Its only the harder edges that unsettles the light sedan. Mind you, this is no Fiat car which glides over any kind of surface thrown at it. Yet it is a comfortable car to be in, most of the time.
Suzuki worked on the stiffness of new Swift’s chassis and the result is a competent handler. Yes, the rear suspension setting is on the softer side to aid ride comfort, still its reasonably fun behind the wheels. On flat highways the car drives very well with good body control and impressive agility. There is bit of a body roll but its well under control.
Throw uneven roads as is with typical India road conditions, the car lose some of its composure with speed. Obviously there is bit of compromise between average speed ride quality and high speed dynamics keeping the nature of car in mind. At times one has to revise the pace to keep the car under total control. Stability on flat roads is adequate though. Maintaining 110-120 kmph is effortless.
Car’s agility in city traffic is remarkable. Turning radius is equivalent to any standard sized hatchback and hence parking this car is a breeze. Light controls and decent all round visibility make things easier. Its really easy to get accustomed to this car.
Steering wheel is among the best bits of this car. EPS is a commendable balance between practicality and fun. While steering is quite light at low speeds aiding city drivability and parking, it gains some weight with speed which inspires confidence in pushing the car. Its quick, responsive and speed sensitive. While pure HPS as is with Fiats and Fords is real enthusiast’s delight, dzire’s EPS is a good compromise of both worlds.
More than anything else, the skinny 165 section tyres are grossly inadequate for this torquey diesel car. Grip level is inadequate for the kind of pace this car is capable of. It is advisable to keep the speed under 120 kmph for stock tyres.
One more glitch attached to the VDi variant of dzire is its average braking capability. They don't have that sharpness as is with the Z variants and the feel of it is quite spongy. Emergency stopping distance is also nothing exceptional to speak about. Maruti SHOULD definitely address this issue and safety is one aspect that cannot be compromised in any way. Lack of ABS and those skinny tyres dont help the matters either.
Other interesting bits
Headlamps beams have good penetration and flow to help you drive safe on highways. Fog lamps are mere parking bulbs literally
Interior ambience at night thanks to orangish-yellow light theme is soothing. They are not harsh on eyes and look pleasant.
Centrally mounted reading lamp has a theatre style dimming effect. They ergonomically placed to light the front….
….and back seats equally well. Check out the ambience at rear seat. Beige color really brightens the cabin.
Some more space could have been generated from the boot. Boot light helps well at night.
Internal rear view mirror gives you a decent sight of back traffic. Stop lamp as seen in the picture can be considered as a blind spot though.
Rear lamps are bright and look good at night.
Front doors look neat but the fabrics and hand rests could have been of darker shade. Faux wood on doors look upmarket...
but its missing on the rear doors which make it look little plain
Overall doesn’t look like a full sized sedan thanks to its very short boot…
… still it looks better than the outgoing model thanks to a more adhesive design
Integrated spoiler and the big chrome strip at the back: dzire has its own sporty bits.
OVERALL:
Sedans in general have distinct advantage over the hatchbacks: They have an independent-spacious boot and have relatively better legroom at back. Unfortunately the new dzire doesn’t have either of these plus points over some of the premium hatches in its price range. Moreover it is still not the best looking car in the business. To be brutally honest the new dzire isn’t exactly a sedan, it’s a notchback version of the new swift and this is what Maruti has intended to do. Maruti has deliberately placed the new car somewhere in between the hatchback and sedan class. While full sized sedans like Manza and Etios are still 80-100 Ks dearer to the equivalent dzire variants, the swift itself is 70Ks cheaper. Car versus car, dzire has definitely improved over its previous avatar in terms of quality, design and engineering which is a good thing. Yes, it lost some of the practical bits of the old car like the big boot, but being a Maruti you are assured with good reliability, service and that peace of mind which is what acts like the X factor for this car. Rest things remain well sorted with a superb engine, nice interiors and that easy to drive nature. Yes, few short comings like average braking, lack of safety features on lower variants and poor tyres need to be addressed as soon as possible.
Overall, the dzire remains a good all rounder with a strong backup organization to appeal the general Indian mass well.
