Gypsy transfer-case neutral issue Quoting from another thread, since I did not want to add OT pics there. Quote:
Originally Posted by gotzuk ...
Unscrew the bolts of the retainer plate of the rubber boot covering the lever and lift up the boot.
Open the cap locking the lever into the transfer case and pull out the lever.
Use a long screwdriver and nudge the shifting pins till you get back into gear. Hope I make sense to you.
Cheers |
Some pics to illustrate the above points made by gotzuk :
Before opening the t-case cover:
After unscrewing the cover :
This is the locking cap, that has to be pressed down, and then turned to release the lever. This can be a bit tricky, and one needs a long screw-driver for this.
The 4wd gear-lever removed
2H position:
4H position
4L position:
This is the troublesome neutral position:
