Team-BHP > 4x4 & Off-Roading > 4x4 Excursions
Old 9th October 2012, 14:41   #1
Tejas@perioimpl's Avatar
Thanked: 9,582 Times
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!
It all started with a call. Mostly everything does nowadays. So, we catch a flight and go to Delhi to have a look at the barren piece of flat land that will need to be converted into a 4WD track for the upcoming Toyota Bootcamp.
The piece of land:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-01.jpg
Mostly sandy in nature:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-02.jpg
Doodling plans over lunch:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-03.jpg
More doodling:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-04.jpg
Rough sketch of the track:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-05.jpg
Final outlines of the track:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-06.jpg
Superimposed on Google Earth:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-07.jpg
Pdf of plans, layout, brief mailed for approval:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-08.jpg
Plans approved and we reach the venue a week ahead of the event to start work on the track:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-09.jpg
Track marking with JCB starts:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-10.jpg
Track outline done:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-11.jpg
Tejas@perioimpl is offline   (19) Thanks
Old 9th October 2012, 15:14   #2
re: 2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!
Obstacle preparation starts:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-12.jpg
Supervising the work:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-12a.jpg
Obstacles being prepared:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-14.jpg
Ditch Preparation:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-15.jpg
JCB hard at work:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-16.jpg
Filling the water ditch prior to testing:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-17.jpg
Work and testing goes on till late night:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-18.jpg
Testing clearances:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-19.jpg
Tejas@perioimpl is offline   (14) Thanks
Old 10th October 2012, 11:45   #3
JCB finalizing the deep ditch:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-20.jpg
Testing ditch clearances:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-21.jpg
Clearance is just fine!:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-22.jpg
Axle twisters (“axle breakers”) being chalked out:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-23.jpg
Checking axle twister clearances:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-24.jpg
Rubble arrives for the base of the mound:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-25.jpg
Work on the mound starts:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-26.jpg
The mound rises:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-27.jpg
More soil on the mound:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-28.jpg
Another layer of rubble sandwiched on the mound:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-29.jpg
Tejas@perioimpl is offline   (16) Thanks
Old 10th October 2012, 12:17   #4
Watering the mound as the JCB compresses the soil:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-30.jpg
If it’s compacted enough for the JCB to climb, it’s good enough for the Fortuner:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-31.jpg
Testing with the Fortuner:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-32.jpg
View of the mound from water ditch:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-33.jpg
Work on slush area starts:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-34.jpg
Adding grass to the slush area to make it “slushy”:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-35.jpg
Water added and lots of runs by a tractor with a plow to make it even more slushy:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-36.jpg
And bingo! We have slush!:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-37.jpg
Old 10th October 2012, 12:32   #5
The Tyre Obstacle:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-38.jpg
Logs arrive for the log obstacles and crossings:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-39.jpg
JCB helps with the parallel log crossing:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-40.jpg
The log rumblers:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-41.jpg
Testing the slide incline. Yeah, we increased the inclination further; ask any participant how tilted the car was!:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-42.jpg
Testing clearances of the alternate mounds and dips:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-43.jpg
Yup, more clearance required here:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-44.jpg
Getting the manual labour to help with the approach, departure and ramp over angles:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-45.jpg
Old 10th October 2012, 12:39   #6
Late night at workshop to test the see saw ramp:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-46.jpg
Yes, the welds hold!:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-47.jpg
The ramp skeleton:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-48.jpg
Works progresses through the night:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-49.jpg
Ramps get delivered in the morning for final assembly:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-50.jpg
First ramp in position:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-51.jpg
Both ramps in place, joined together by a few bars welded prior to testing:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-52.jpg
Fortuner approaches the ramp:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-53.jpg
Ramp works!:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-54.jpg
Tejas@perioimpl is offline   (13) Thanks
Old 10th October 2012, 13:06   #7
Here's a video of the track obstacles that was shot by Toyota:
Last edited by bblost : 10th October 2012 at 13:20. Reason: Removed the www part in the url.
Old 10th October 2012, 13:18   #8
A few pics of the track while it was being prepared from a nearby building:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-image-1.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-image-2.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-image.jpg
Last edited by bblost : 10th October 2012 at 13:55. Reason: embedded the pictures.
Tejas@perioimpl is offline   (8) Thanks
Old 10th October 2012, 13:52   #9
A few photos of the event off the web:
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-47558_10151106044133650_1833713513_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-61423_10151106043863650_1095125453_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-66145_10151101961183650_476727568_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-150161_10151106044318650_1376988223_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-199555_10151103432898650_1273223027_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-223260_10151103089083650_2116134531_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-224406_10151101961428650_896506039_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-246548_10151101961258650_2106097174_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-254465_10151103087823650_279722087_n.jpg
2012 Toyota Bootcamp : How to convert barren land into a 4WD Track!-254617_10151103086373650_1882105168_n.jpg
Tejas@perioimpl is offline   (20) Thanks
Old 10th October 2012, 13:58   #10
bblost's Avatar
Thanked: 15,366 Times
Thread moved from Assembly Line
Thanks for Sharing.
bblost is offline
Old 10th October 2012, 17:52   #11
nilanjanray's Avatar
Thanked: 2,926 Times
Brilliant thread, thanks for sharing how the course got conceptualized from scratch!
I only wish Toyota would train the ASCs to cater for the offroading crowd.
When I had done this course in Bangalore, and went to the ASC later, they didn't have an clue on what to check and what/how to maintain after such slushy offroading. E.g. proper tightening, greasing etc. Or for that matter, checking the alternator, starter motor...my starter motor was affected later because dirt/mud/water would have gone inside and created some sort of coating, and it started malfunctioning after a few months. A simple check-up and wiping/cleaning would have prevented what happened. I didn't know then what I know now, and many folks like me would be left at the mercy of the incompetent ASCs for post-bootcamp maintenance and check-ups.
Perhaps you can pass on the message to the organizers - to create a checklist of things to do and things to check after such a bootcamp at the ASC.
nilanjanray is offline   (3) Thanks
Old 10th October 2012, 18:39   #12
parsh's Avatar
Thanked: 1,298 Times
Feels like having been there all this while, right from ground 0 to the actual event. I would have thought, such things (the planning and execution) etc were not to be made public but the public event could be. But seeing them here, maybe it is not so. Isn't there confidentiality etc involved, not that it seems to be big trade secret. But loved it absolutely. Thanks a ton for sharing complete detail, especially since it involves the favorite SUV TFort in the new Avatar.
parsh is offline   (1) Thanks
Old 10th October 2012, 22:04   #13
Ahmed's Avatar
Thanked: 307 Times
Thanks a lot for sharing this information. Well deserved 5 stars on the same. After reading your thread - it felt like I was there and felt each and everything happening there.
Wondering when this will come back to Mumbai/Pune... My ride needs to flex a bit!
Ahmed is offline   (1) Thanks
Old 11th October 2012, 02:50   #14
phamilyman's Avatar
Thanked: 4,642 Times
brilliant job done boss. i am at a loss of words
i think dentists make some of the best engineers!!
phamilyman is offline   (3) Thanks
Old 11th October 2012, 10:14   #15
Thanked: 51 Times
Excellent Track by Allan, Dr. Tejas and the team. The event was very well organised and I hope to see the guys next year with even more challenges.
zipperone is offline   (1) Thanks
