See.. I think we have to start from basics here..
What is a 4WD or an AWD?..
In a four wheeled car/van/truck/SUV.. Usually for on-tarmac use, two
driving wheels are enough for all practical purposes.. But, when you venture out to areas with less traction(grip) what do you do? First you try and increase your grip levels from the driven two wheels by reducing air or using traction aids etc, but if its still not enough?.. You will wish that if only the other two wheels could also be driven and give you more grip..
Well..thats exactly what the engineers have done in a 4WD/AWD, develop a mechanism where all four wheels are
driven.
Why the low ratio?.
Now that you have all four wheels being driven, you can do better gradients than before.. but you want to do more.. You also drive through very bad broken terrain that you have to be very slow and controlled. Doing this in your regular gear ratios is demanding for the driver and the system.. Hence the engineers have installed a low ratio gearbox which makes the vehicle go even slower and helps tackle even better gradients.
Why AWD on tarmac?
Now you have four wheels driven for areas where there is very less grip. But, this configuration of 4 wheel drive cannot be driven in areas where you have good traction (grip).. So you switch to 2WD.. But what about hilly snowy areas where you have freequent intervals of good grip and bad grip coming and going.. It'll be a pain to always switch between gears. Worse, you might also miss switching to 4WD and end up spining your wheels and car.. So engineers have come up with the AWD mechanism, where you can drive on good grip (tarmac) as well as bad grip areas with no capability compromise...
What about all the traction aids?
Well, now you have all four wheels driven.. but something called as the differentials which help you so much on road, cause problems offroad and make one or two wheels not be driven. So engineers have developed tech like diff-lockers, Brake Locking, Limited Slip Diffs etc.. to ensure all four wheels remain driven as required.
Now, coming to the question.. The answer will depend on what you want your vehicle to do?
- If you want capability of driving on slippery surface as well as surface with good grip simentaneously, then AWD is more capable for that.
- If you want gradeability then choose a vehicle with a low ratio gearbox.
- If you want both of the above then get something like the Fortuner, which has a low ratio gearbox and a center diff which allows it to be AWD and also has an intelligent braking system to give all traction aid, and also a switchable locker..
a 4x4 without MLD is useless.
Going by that logic.. All the Gypsys and MM540/550, Major, CJ500, Classic, CL340, Old jeeps are all useless..
