guys i found this DIY snorkel, which is very easy and the material is available in hardware shops.
once you guys see the photos, you will know what items are required.
i hope to find more DIY for all of jeepers here and post them. please dont give me any credit, i just found it and posting for all of us.
happy making!cheers:
i hope many jeepers take advantage of this DIY snorkel.
Another nice use of sewer pipes. Good work bro.
Isn't it a T pipe in that case to what is the other side of the section connected ? Parm, any more number of pictures ? and I worried whether M-seal can really be that water tight !!
thats the only number of photos i got for this home made snorkel.
Parm, there is no point to this snorkel if water fording is the intention.
Checkout this detailed water-proofing advice:
Yahoo! Groups
I did try fabricating one for the Classic, went the whole hog. Fitted it, started rattling like crazy and eventually discarded it. Looked crude too :D
Originally Posted by Spitfire
(Post 978263)
I did try fabricating one for the Classic, went the whole hog. Fitted it, started rattling like crazy and eventually discarded it. Looked crude too :D |
Spitfire, Can you post a picture please.
Brilliant DIY.
During rains that free flow air intake snorkel will double up as a free flow water intake too !!:uncontrol
Originally Posted by gotzuk
(Post 1129474)
Brilliant DIY.
Cheers |
Good point there.
Wont it be more water retardant if its bent a little more downwords?
As Laxman's Safari one?
Vinay Rathore
Originally Posted by DesertKing
(Post 1129411)
Spitfire, Can you post a picture please. |
No picture buddy. This was sometime back. I do have line sketches of the length of the hose pipes required and the clamps that had to be fabricated.
Was a very bad project. Was totally DIY, didnt spend more then 1000 bucks on the whole setup. Patching up the stupid hole i made in the bonnet was costlier :Frustrati
Not worth it or required. I never fordged any water body deep enough to justify the snorkel. Eventually it got loose and started vibrating - bad engineering.
Like DD said trying to save your electricals is a bigger challenge.
But if you have to have it - there is lot of info on the net on how to make one. But a lot of parameters are to be considered. If you can see how the one on the Gurkha is made it may give you a fair idea.
Does any of the Army 550's come with one? If they do that would be a good reference.
I have a generic question about snorkels, but this is the only thread which talks about snorkels, so here goes.
I have seen many vehicles with snorkel, and the inlet facing forward. At high speed, in torrential(I am talking about 10cm/hr kind of torrential) rain, won't lot of water go into the engine through the snorkel? Will it not damage the engine?
Now Safari Snorkels have a design which allows heavier rain drops to fall "out". However, most desi snorkels I have seen do not have any special structure
The paper element would become damp and choke up well before it lets liquid water through. (I am not talking of the inlet being dunked under water)
The original snorkel (used on Diesel Electric submarines) had elaborate water traps. And the collected water was pumped out. Never really looked critically at car snorkels, but am sure a properly designed one needs a water trap.
Not related to a snorkel, but personal experience (NA Petrol) has made me very sceptical of 'Ram Air' intakes.
Sutripta
Originally Posted by tsk1979
(Post 2865797)
Now Safari Snorkels have a design which allows heavier rain drops to fall "out". However, most desi snorkels I have seen do not have any special structure |
Yes Safari snokels separates water. I have a counter question to your q. Many of recent cars (petrol and diesel) have ram air intakes where a funnel faces the front through the grill (even the puny alto and wagonr). Will they also not behave same as a 'desi' snorkel facing forward?
I am speculating that the rain water is not enough to cause a hydrolock. Inlet needs to submerged in water.
cheers
vishwas
Originally Posted by vishwaschettri
(Post 2869691)
cheers
vishwas |
An observation - if you see the snorkels for LR Defenders - they're mostly mushroom shaped - not ram air intakes - is this because of the wet weather in UK ? Same is the case for pre-cleaners on heavy truck diesel engines
As I understand - a snorkel serves the function of assisting in delivering clean, dry and cold air to the engine,
so if an NA engine has the air intake specified @ xyz cfm (cubic feet per minute) - for optimal fuel burning, how does 'ram'ming air into the intake help ?
Unless this serves as a cheap supercharger alternative?
Let's take the water fording scenario - you've got to keep the air intake above water for obvious reasons, shouldn't the vehicle exhaust also be raised by the same logic (not submerged) ?
